Author: Subject: Busa & GIPRO gear indicator configuration
timbo7
posted on 25/4/08 at 08:27 PM Reply With Quote
I'm running busa clocks with speedo healer. Speedo pick up from gearbox output flange/prop home made pick ups.
Problems: I'm getting a back feed through the neutral light when NOT in neutral.. it flickers green.
As anyone else here used the GIPRO gear indicator? Why I ask is that I cannot seem to auto configure gear display readings - I can run through the learning procedure but once stored the display fails to follow the actual gears.
Anyone experience with this that can help?
WESTFIELD HAYABUSA 1400 - SOLD
Miks15
posted on 25/4/08 at 09:29 PM Reply With Quote
sorry dont know your answer but i think you will need to reduce the size of your avatar! barley any room to read your post!
Edit to say cheers
[Edited on 25/4/08 by Miks15]
timbo7
posted on 26/4/08 at 02:07 PM Reply With Quote
Ok.. update.
I get an F1 warning light on clocks when GIPRO connected = C31 = GPS sensor fault. When disconnect GIPRO and and reconnect loom 3 way white triangular connector F1 light goes out.
Can someone check their GIPRO wiring for me plz.
GIPRO male to loom female
R to U
W to K
B to BW
GIPRO female to loom male
R to U
G to R
B to B
timbo7
posted on 26/4/08 at 03:56 PM Reply With Quote
not wiring... GIPRO confirmed direct. Now checking GP signal wire resitance. Why do I get the sneaking suspision this is going to end up a ballacs
iiyama
posted on 27/4/08 at 11:27 AM Reply With Quote
slightly off topic, but how did you pull up the dealer mode diagnostics? Jump the two cables at the dealer mode socket?
If its broke, fix it. If it aint broke, take it apart and find out how it works!
timbo7
posted on 27/4/08 at 11:35 AM Reply With Quote
yep!
iiyama
posted on 27/4/08 at 11:37 AM Reply With Quote
Cheers bud.
timbo7
posted on 27/4/08 at 01:06 PM Reply With Quote
Gp voltage readings should be
Neutral + 5.0V
1st 1.8V
2nd 2.4V
3rdn 3.1V
4th 3.7V
5th 4.4V
6th 4.8V
I'm getting 4.88-4.93V but only when ign running. No V reading when ign powered up.
1st problem could be ign switch wiring supply feeds.
2nd problem is the back light feed through the neutral switch when not in neutral... earth problem?
timbo7
posted on 1/5/08 at 07:14 PM Reply With Quote
problem SORTED - earth wire on GP sensor has been shredded by ring gear.
NEXT problem. The large 30mm nut on the layshaft - clockwise or anticlockwise. Getting the punched section of the nut is proving a pain in the ass. Any one removed clutch basket/ring gear that can offer assistance re. I have no Haynes Manual. Do I need a tool to clamp the ring gear to remove the nut?
iiyama
posted on 1/5/08 at 07:18 PM Reply With Quote
Main nut that holds the sproket on is a normal right hand thread but its damn tight. Cant remember the setting but its something like 130nm.
Pm me your email ady and Ill send some PDF's over.
timbo7
posted on 1/5/08 at 07:20 PM Reply With Quote
tim.abraham@peugeotmail.co.uk
Cheers mucker
timbo7
posted on 1/5/08 at 07:31 PM Reply With Quote
ok> so there is a special clamping tool for the clutch sleeve holder.. bugger!
anyone used any makeshift objects to clamp same?
timbo7
posted on 1/5/08 at 08:35 PM Reply With Quote
sorted.. brute force, large clamping bar in prop output UJ joint & heh presto.
timbo7
posted on 1/5/08 at 08:43 PM Reply With Quote
Help on this forum is great.. I seem to answer my one posts
Jason Fletcher
posted on 2/5/08 at 10:20 PM Reply With Quote
I did mine up with a windy gun. Seemed to work fine.
Good info on the GI Pro by the way. I am yet to sort mine out.
Jason
timbo7
posted on 3/5/08 at 08:14 AM Reply With Quote
New GP sensor fitted. Clutch hub refitted. GIPRO fitted - working correctly now on GIPRO 'd' setting - no programming required.
timbo7
posted on 3/5/08 at 05:05 PM Reply With Quote
"Windy gun"
Nice technical decription
