tegwin
| posted on 28/4/08 at 04:56 PM |
Floor mounted peddlebox.....
I have a floor mounted peddlebox in my car with a hydraulic clutch MC....
I need to convert it to cable but cant think of a suitable method of levering the cable......The lever arm would effectivley be in the road
somewhere....
So how have others managed floor mounted cable clutches?
Pics appreciated
www.verticalhorizonsmedia.tv
Miks15
| posted on 28/4/08 at 05:02 PM |
cant you just move the pivot point up slightly? then ur cable lever will still be within the pedal box
Mix
| posted on 28/4/08 at 05:08 PM |
Have you measured the required throw at the clutch actuation arm, (the one at the bell housing)?
Just a thought
Mick
clairetoo
| posted on 28/4/08 at 05:12 PM |
I just went the other way - cable to hydraulic I just re-drilled the pivot at the bottom and cut off the unwanted bit - sounds like you would have
to do the reverse .
[img][/img]
Its cuz I is blond , innit
Claire xx
Will weld for food......
ReMan
| posted on 28/4/08 at 05:13 PM |
Probably not the answer you want, but if you do a google you will find floor mounted pedal units specifically designed for cable clutches.
clairetoo
| posted on 28/4/08 at 05:14 PM |
Forgot to add - and then make a new clutch pedal !
Claire xx
tegwin
| posted on 28/4/08 at 08:14 PM |
Hmm...this is an interesting idea
Im not sure if all bike engines are similar, but roughly how much cable movement am I going to need for a BEC clutch? (ZX9R to be precise)
clairetoo
| posted on 29/4/08 at 11:13 AM |
Now that is nice !
Claire xx
