Pdlewis
| posted on 17/5/08 at 08:33 PM |
Bec gear cable
Will this be alright for a paddle shift?
Link
zilspeed
| posted on 17/5/08 at 08:40 PM |
fifty Quid !!!
'Kin 'ell...
I believe that price may be subject to the 'it's for a kit car, so it costs more' tax.
what about here ?
Pdlewis
| posted on 17/5/08 at 08:42 PM |
Thats a more friendly price
marmot0
| posted on 17/5/08 at 08:44 PM |
They are great cables but you can get one made up to your own specs for that price
| posted on 17/5/08 at 09:19 PM |
IT would work but I doubt your wallet would recover for quite a few weeks! That's flipping expensive!!!!
get ye to a boat chandlers....
tegwin
| posted on 17/5/08 at 09:36 PM |
Ouch thats a lot!
I bought one of the telexlex cables off ebay for £7.50 brand new.... It does have some weird thread on it, but should do the job....it was
cheap!...
It doesnt use bolt in bulkhead fittings like that one, it has slot in fittings which take a bit more thought!
www.verticalhorizonsmedia.tv
dhutch
| posted on 17/5/08 at 10:21 PM |
And thats not somthing you hear many people say!
What about this:
http://cgi.ebay.co.uk/New-Teleflex-Morse-33c-01000-P-1-00m-Control-Cable_W0QQitemZ150076522138QQihZ005QQcategoryZ15271QQrdZ1QQssPageNameZWD1VQQcmdZVie
wItemQQ_trksidZp1638Q2em118Q2el1247
Daniel
Pdlewis
| posted on 17/5/08 at 10:40 PM |
Cheers guys as always,
Tegwin was it easyenough to overcome not having the bulkhead bolts?
Paul
tegwin
| posted on 18/5/08 at 09:54 AM |
Yes.....really easy!
I used some 4mm angle, drilled a hole, filed it into a slot, then drilled tow small holes behind...
Now all I do is slide the cable into place, then lock the cable in by twisting stainless locking wire around the cable into the small holes....
For what you want it to do, it will be fine!!!
If you want some pics U2u me and il take some
NS Dev
| posted on 18/5/08 at 10:02 AM |
I am using the teleflex cable on my twin engine grasser (two of them obviously!! )
The slotted end is easy to solve, its exactly 3/8" OD, so run a 3/8" unf die down it and then you can mount it with a pair of 3/8"
unf half nuts (as used on imperial brake pipe bulkhead fittings.
The "funny thread" on the end fittings is 10-32 unf, which is as good as makes no difference M5.
I am using M5 female rod ends from McGill Motorsport each end, think they are a couple of quid each.
| posted on 18/5/08 at 10:13 AM |
You could get the 10 metre one for £53 from the boat place, imagine the fun changing gear with that There's
cable-tec who will make a cable to your spec.
