Author: Subject: off set of a wheel
tjoh84
posted on 9/8/08 at 08:21 PM Reply With Quote
off set of a wheel
how can i find out the off set of a wheel
cortina alloys like escort mark 2
been told 17 and 18 whats best
big_wasa
posted on 9/8/08 at 08:55 PM Reply With Quote
If its a standard ford wheel it could well be on it.
ie et19 = 19mm offset.
adithorp
posted on 9/8/08 at 09:03 PM Reply With Quote
The ET might be marked on the wheel.
If not then its possible to measure it. The ET is the distance between the centre line of the wheel and the mounting face. Positive offset is towards the outer edge from the centre.
A strieght edge across both sides and measure between them to get the rim width and divide this by 2 to get the centre line measurment. Then measure from the back strieght edge to the mounting face. Subtract the first amount from this and you've got the ET.
adrian
http://jpsc.org.uk/forum/
RichardK
posted on 9/8/08 at 09:12 PM Reply With Quote
Enough info to make your eyes bleed HERE page 2 has ofset info
Rich
[Edited on 9/8/08 by RichardK]
Gallery updated 11/01/2011
wicket
posted on 10/8/08 at 11:37 AM Reply With Quote
I've got Capri Laser alloys and the size is cast into one of the spokes on the front of the wheel and is 6Jx13xCHx19
