Author: Subject: word help
locoboy
posted on 5/9/08 at 07:44 AM Reply With Quote
word help
Can anyone tell me how to split an a4 page into 6 equal sized bits? i need make and print off some telephone enquire cards.
I want to be able to click in each section of the a4 sheet and have it act like a whole page, ie when i click the centre text button it will centre it within that part of the whole page............if you know what i mean!
Colin
Locoboy
lsdweb
posted on 5/9/08 at 07:57 AM Reply With Quote
3 X 2 table.
You can then format the text in the individual cells. It'll take a bit of fiddling to get the right size but shouldn't take too long!
Wyn
[Edited on 5/9/08 by lsdweb]
posted on 5/9/08 at 08:04 AM Reply With Quote
Or do a single page flyer, copy it six times onto seperate pages then under printing options do "pages per sheet" and make that six.
Humbug
posted on 5/9/08 at 08:06 AM Reply With Quote
Simplest way would be to create a table, e.g. (this is on Word 2002 - may be slightly different for other versions):
On the menu, select Table->Insert->Table
Choose 2 columns, 3 rows and click OK
On the menu, select Table->Select->Table
On the menu select Format->Borders and Shading
Click the setting "None" and click OK (this takes away the lines when your print)
On the menu, select Table->Table Properties
Select the Alignment and text wrapping you want
Don't click OK yet
Click the Row tab
Check the Specify Height box, give a height of say 9cm and select Exactly (this will make sure that the boxes don't change depending on the text
Don't click OK yet
Click the Cell tab
Select the vertical alignment you want
Now click OK
You might need to tweak the row height depending on what minimum margins your printer uses and what margins/borders you have set up in that document
Good luck!
Simon
will121
posted on 5/9/08 at 11:41 AM Reply With Quote
how about doing it as if you were printing on pre cut adhesive lables, type what you want once and the just pick the layout of number of columns and rows and print?
Tools
-letters & mailing
--Envolopes& lables
---options find layout or custome size
----type in what you want to see
----print
locoboy
posted on 5/9/08 at 07:48 PM Reply With Quote
I will give the labels forma a try first i think, seemed to be less steps to it!
Thanks for all the advice, what a knowledgable bunch we all are [/]smug[]
Locoboy
