Author: Subject: sierra rear hubs & splines
mads
posted on 15/9/08 at 12:52 PM Reply With Quote
as topic says... am after rear hubs for MK Indy and also after splines for rear as well (got the driveshafts already but guy had wrecked the splines when taking them off)
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
Paul TigerB6
posted on 15/9/08 at 01:01 PM Reply With Quote
There are different push-in type driveshafts - not sure if you are after a pair of these or the outer splines from a pair of bolt on types??
Probably best to check what you have by counting the splines and posting it up on here. There was a thread somewhere about this - will have a look for you now
This might help you
[Edited on 15/9/08 by Paul TigerB6]
mads
posted on 15/9/08 at 05:02 PM Reply With Quote
sorry, should have been more specific. It is the outer splines from bolt-on types.
