lsdweb
posted on 8/10/08 at 10:25 PM |
Rear Upright Weight?
Hi All
Does anybody know the weight of a 'normal' rear upright on an independent back end?
I've got some cast alloy ones I may use but they seem heavy at just under 6kg including drive flange and CV.
Regards
Wyn
Wadders
posted on 8/10/08 at 11:24 PM |
I never weighed the rear uprights on the ST which are fabbed from what looks like 5mm plate, but they didn't feel particularly heavy.
however the sierra bits of the equation felt very heavy, i machined some weight off them, but they are still lardy.
6kg all in sounds pretty light to me.
Have seen lobros that have been milled to shave some weight, but the main culprit seems to be the output flange/shafts.
Al
Originally posted by lsdweb
Hi All
Regards
Wyn
liam.mccaffrey
posted on 8/10/08 at 11:38 PM |
I can't check yet Wyn but I'd be surprised if my mx5 rear uprights are over 6kg. IIRC mx5 rears are quite svelte
Build Blog
Build Photo Album
minitici
posted on 9/10/08 at 07:57 AM |
Just weighed a Westfield alloy rear upright with drive flange, stub axle, disc and Wilwood 4 pot caliper - 11.7Kg
[7.7Kg without disc]
lsdweb
posted on 9/10/08 at 07:54 PM |
I'll weigh mine with the disc and caliper now! That's a good benchmark, seeing as it's a Westfield!
lsdweb
posted on 9/10/08 at 08:37 PM |
Just weighed it all -
Upright - about 5.6kg
Disc (really skinny) -2.4 kg
Caliper & pads - AP Alloy - 1.5kg
That's a total of 9.7 kg. Worth the grief of fitting a non standard upright I think!
The only down side is the PCD is roughly 95.5mm
