R1 5VY rev signal pickup, where?
MK9R - 25/2/11 at 08:05 AM
Just connecting up the digidash, what wire should i break into to get the rpm signal???
RickRick - 25/2/11 at 08:24 AM
yellow black from ecu, though there are 2 yellow blacks i think!
[Edited on 25/2/11 by RickRick]
nitram38 - 25/2/11 at 09:46 AM
Thats ok if you don't have any fault codes on your engine. otherwise your revs will do strange things.
I think I used an earth from one of the coil packs.....from memory!
Kosmo - 4/3/11 at 07:25 AM
I used the coil pack with no problems....
