M8 banjo bolt with nipple?
T66 - 1/11/13 at 12:57 PM
Hi
I'm busy doing the clutch slave cylinder, and the inlet port on the slave is too close to the front sprocket Cush drive. Plan to block the inlet and feed the cylinder from the top through bleed nipple.
It's M8 x 1.25 thread, can find lots of M10 bleed banjos, but no M8s. If necessary i will drill and tap one.
Any suggestions where to get one please ?
prawnabie - 1/11/13 at 01:34 PM
Russ Bost my be able to help you out as he has with me a number of times regarding hyradulic brake parts.
MakeEverything - 1/11/13 at 01:39 PM
Originally posted by T66
Hi
Loads on Ebay mate. I always look on here first, then use the details as a reference if the prices / delivery conditions arent good enough.
http://www.ebay.co.uk/sch/i.html?_trksid=p4840.m570.l1313&_nkw=M8+Banjo&_sacat=0&_from=R40
40inches - 1/11/13 at 01:40 PM
Isn't M8x1.25 motorcycle fitting? Try Russ, as said or here
T66 - 1/11/13 at 02:14 PM
I've had a look through RussBosts site but nothing obvious, I need to measure up for brake lines as well so I may as well order the lot in one hit.
Yes it's a metric Honda Blackbird cylinder.
This is what I'm after in m8 x. 1.25.
http://www.ebay.co.uk/itm/M10-x-1-25-banjo-bolt-with-bleed-screw-nipple-/160724310059?pt=UK_Motorcycle_Parts_13&hash=item256bea582b
Cheers guys
