luego velocity wheels
oggierock - 23/2/15 at 04:02 PM
This may be a really dumb question but?:
Im in need of some new wheels and tyres for my luego velocity as it has big old 17" rims on at the moment.
Can anybody help with what spec would be good to look for with PCD etc.
What have you guys got and any suggestions. I was thi nking team dynamics pro race 1.2 or similar.
Paul
matt5964 - 23/2/15 at 07:00 PM
I have 15" 6.5j on mine 4x108 et38 and they fit just fine. And run 195/55/15 on front and 205/55/15 tyres toyo R1R's
You could go 13" pdc would be the same and et if j is same.
Worzey - 23/2/15 at 09:38 PM
I started with 17" wheels on my Velocity but soon changed to 15" Team dynamics. It transformed the car.
It should be a standard Ford fitment so Matts specs look fine . Be careful if you go for a 13" wheel if you have Ford Sierra rear calipers as I believe you may need to modify them slightly for clearance. You could go for Pro Race 14" wheels but tyres might be harder to fine.
SteveWallace - 24/2/15 at 08:53 AM
Don't forget to change the calibration of the speedo if you change the rolling radius of the wheels...
