Electric power steering pump, how does it work?
Mr Whippy - 18/4/16 at 02:16 PM
Hi,
I’ve been looking around the web and seeing electric power steering pumps for very little money, I’m doing another P/S conversion on an old Landy and the last time mounting the mechanical belt driven pump was a total massive pain since they never had one as standard and mounting positions are very poor.
So these pumps, do they need a signal from something like in the steering column telling them when to come on or are the just running all the time much as the mechanical pump does.
If it just runs all the time then this would be a fantastic and so much easier to fit. Is there any particular version that people would recommend? (the cheaper and simpler the better tbh)
I’m again using a range rover P38 steering box and a 90 column. Was going to use a Shogun pump on the 2 ¼ petrol but would like to avoid that if possible.
dinosaurjuice - 18/4/16 at 03:27 PM
The Ford 'EPAS' electro-hydraulic pumps are sent commands over CANBUS so probably best avoided.
Lots of info on the net about Fiat and Vauxhall electric steering columns, easiest solution i think.
Will
coozer - 18/4/16 at 03:37 PM
I have hear an electric pass pump and rack off an old Peugeot 106.
It looks like an electric pump replacing a hydro one..
rusty nuts - 18/4/16 at 05:55 PM
Have a look at the Vauxhall Astra G electric power steering pump from around 1998 onwards , I suspect that it would work using a relay activated by the alternator to supply power when the engine is running . Power steering doesn't work on the Astra unless the alternator is charging . Found mounted low down just behind the gearbox .
[Edited on 18/4/16 by rusty nuts]
blakep82 - 18/4/16 at 06:29 PM
200 or 300tdi engine conversion from a disco, with the steering box, oil reservoir and pipes also out of it?
owelly - 18/4/16 at 08:40 PM
Takeba looksy at the Vauxhall Corsa EPAS. It's an all electric unit built into the column. I used one from a WagonR/Agila.
Mr Whippy - 19/4/16 at 06:55 AM
thanks but the engines are totally different and the older engines are not great for mounting pumps too
Mr Whippy - 19/4/16 at 06:58 AM
Thanks yeah this does look like it will do the trick and very cheap too. Been looking at the wiring diagrams and it looks a doddle wish I'd used this the last time.
omega 24 v6 - 19/4/16 at 07:10 AM
Scott. The corsa is prob the way to go, but,any I have seen on rally cars are equiped with a little control box and a variable sensor mounted to the dash ( poss just a variable pot) I believe they are widely available.
dinosaurjuice - 19/4/16 at 07:17 AM
CBS do a controller for less than £50 http://www.carbuildersolutions.com/uk/corsa-power-steering-controller
MikeR - 19/4/16 at 09:29 AM
Astra G around 1998 - avoid unless you've got the Vauxhall (not recalled but should have been) replacement.
I had one, the replacement pump cost nearly a 1k as you also got a steering rack, pipes and electrics - ie the whole blooming lot.
owelly - 19/4/16 at 02:55 PM
The Vauxhall EPAS I used is very simple to wire up. A fat +ve and a fat -ve. Thin cables for the rpm sensor and speed sensor. The unit does nowt until it sees a rpm signal to know the engine is running. The unit has three levels of assistance. Maximum when there is no speed signal and minimum when there's a fast signal.
