Ford Focus 2ltr Blacktop Engine, type 9 bellhousing, LRS 707 Starter, Silvertop DEEP ECU, Airflow meter & Throttle body & Standalone wiring
loom for RWD Conversion.
£300 ono..
2.0 Blacktop Zetec &
Conversion parts
If you brake it i could do with an ecu for a mates, his wont play ball.
cheers
Does this have the belt pulley changed as required in Westfield and seven type conversions?
Looking to replace a damaged silver top, would not require the loom or ecu but would need to know if you would be willing to pallett for courier to
bristol.
