Pair of 3" Sabelt harnesses, replaced due to change of sprint class meaning I needed in date belts. Depending on what tyres/engine size/class you
are in these would still be legal in springs and hillclimb despite being out of their FIA date range.
Both can be used as 4 point harnesses with an additional pair of anti-submarine crotch straps included to make one a six point if required. One
harness has had significantly less use as it was on the passenger side, so only used literally less than 10 times in the 5 years I have owned the
car!
All metal buckles and adjusters, proper quality bits of kit and very expensive when new. Ideal for trackdays or sprints/hills if your car and class
suit.
£80 for the pair including UK mainland delivery, excluding Highlands.
Uncovered replica of a very comfortable Lotus 26R seat. Basic but comfortable and fair condition with only a bit of crazing in the bottom of one
corner, the main bonus is it barely tips the scales over the 1kg mark, I was going to replace it with a kids kart seat at one point but when I weighed
it I changed my mind!! Measures 37cm at the hips. Was a passenger seat in my SEiW and has barely had any use due to the car being sprint and hillclimb
specific and passengers having to deal with an air bottle, battery and two ECUs in the foot well!
£60 including postage to mainland UK excluding Highlands.
Custom made T45 roll bar with rear stays and removable petty strut. Replaced as it's no longer legal for MSA sprints and hillclimbs. Much lighter
than standard roll bars due to using high spec material (met FIA and MSA specs previously but as it was custom (but professionally) made for my car i
didnt have the paperwork MSA no requires). Only weighs about 6kg all in. Was welded to my Westfield and has been cut off so will need adapting to
suit. Or just cut it up for some cheap T25 tubing! 97cm between upright centres, 41cm main hoop height, 80cm rear stays, 140cm strut. £20 collected
from Alfreton or Ilkeston.
Sabelt sold pending payment
Sabelt sold and fitted by their new owner already!
Seat and roll bar still available.
