Ultra low entry scissor action jack for my Radical
carpmart - 13/3/16 at 09:49 PM
anyone got one or seen one FS please?
JacksAvon - 13/3/16 at 10:23 PM
one of these?
quick lift jack
daniel mason - 13/3/16 at 10:23 PM
I used to push it onto a 1" battern then up onto a 4" x 2" then a standard long reach quick jack works fine. The rear is easy to jack up with stsndard quick jack
daniel mason - 13/3/16 at 10:24 PM
That 50mm jack wouldn't have gone under mine. I only had 40mm ground clearance
[Edited on 13/3/16 by daniel mason]
Dopdog - 13/3/16 at 10:32 PM
I like the way he says he can do it at a lower price than others
and as you say Dan it will not go under our cars
daniel mason - 13/3/16 at 10:50 PM
Radicals are worse than single seaters to jack up at the front. The front body overhang is quite severe! You really need the front wheels on some wood.
Brook_lands - 14/3/16 at 07:54 AM
We use this sort of thing
http://www.demon-tweeks.co.uk/motorsport/rally-accessories/race-ramps-trak-jax-jack-clearance-ramps
Quite easy to make your own to suit if you want to go Locost.
HowardB - 14/3/16 at 08:15 AM
I made one,... I guess it can be adjusted to suit,...
locost low jack
locost low jack
or can you make an adaptor to use something like the rally jacks? Or a tip over one like they use in F1?
hth
daniel mason - 14/3/16 at 08:31 AM
I have a set of those ramps like Brookland. But the prosport wouldn't even go up them without being on battern
gaz_gaz - 14/3/16 at 08:31 AM
I used this with my Radical
http://www.adr-engineering.co.uk/shop-list-item.php?item=113&shop=Racing&time=1421961050
carpmart - 15/3/16 at 11:01 AM
Thanks for all the replies chaps..
I've got a set of shallow angle ramps I roll it onto, but just wanted something a little easier to use and more 'elegant'.
Johneturbo - 17/9/18 at 11:19 AM
locost low jack
locost low jack
hth
I know it's an old thread but been searching for something like this, as the only way i can jack the car up is rolling it on blocks of wood as the MNR nose cone protrudes a long way forward.
Howard how low is the jack? and how much travel do you have?
[Edited on 17/9/18 by Johneturbo]
HowardB - 17/9/18 at 11:30 AM
If you are using the very front then 20mm, other wise depends on the size of the rollers/wheels, 40mm should be possible. It goes "over centre" so the lift height is just less than the length of the front arms, I have about 200mm on mine, enough in most cases.
Johneturbo - 17/9/18 at 01:58 PM
Yes 200mm would be plenty
Do you have a diagram on measurements ect as I would like to build something like this
HowardB - 17/9/18 at 02:02 PM
I did have a set of drawings for it, I have changed PC a few times since, I'll see if I can find it. u2u me your email and I'll send what I can or take some more pics...
Johneturbo - 17/9/18 at 03:01 PM
Cool, cheers I'll send you my email
