7 grille vinyl template
ste - 13/5/16 at 05:16 AM
Anyone have or know where I can get a vinyl 7 logo i can use to spray on my grille?
I want to use it to mask my grille mesh so needs to look like this
regards
[Edited on 13/5/16 by ste]
Slater - 13/5/16 at 07:47 AM
I'd suggest printing off that picture, re-scaling it to the size you want. If you need a vinyl template take it to your local signwriter place they will be able to cut out that shape, or provide you with an offcut to do it yourself.
nick205 - 13/5/16 at 09:46 AM
Likewise, I'd go for a print out and cut one yourself. If you need help printing I can probably do it on A3 paper at work for you - U2U me if you need to.
Humbug - 13/5/16 at 06:25 PM
I printed off a pic on paper, stuck it on some ali sheet and cut it out then fixed it to the grill
http://locostbuilders.co.uk/forum/4/viewthread.php?tid=67901
[Edited on 13.05.2016 by Humbug]
ste - 16/5/16 at 11:27 AM
Thanks for the suggestions
trextr7monkey - 16/5/16 at 03:22 PM
How about cutting a stencil with laser cutter then overlaying on radiator and spraying?
loggyboy - 16/5/16 at 03:44 PM
I used a guy on ebay, only cost a few quid but was for something much smaller. http://stores.ebay.co.uk/N2Grafix
If you can get or make vector based image file for it most sticker places will cut it for a reasonable price.
sevaun - 26/5/16 at 07:33 AM
Why go to all that trouble. Just stick a sheet of vinyl over the things, use a sharp modelling knife to cut around the template and job's done - or am I missing something here?
Rich
