Cortina Mk 3. 4 or 5 column surrounds
russbost - 16/10/23 at 09:26 AM
Bit of a long shot, but I'm sure some of you must have broken Cortina's for bits, I need a lower half column shroud for a Mk3, 4 or 5, not sure they are all the same, obviously a complete set of upper & lower would ensure they match
Anyone got anything they're not looking for a fortune for?
Still need some Bosch distributor cap clips too ...
Cheers Russ
Mr Whippy - 17/10/23 at 06:15 AM
Have you got a 3D printer?
russbost - 17/10/23 at 08:15 AM
Nope, & if I did, I would have thought unless someone has already created the files to print it would be quite a difficult job to draw up?
Does anyone know of any 3D files that already exist for Cortina column shrouds? I do have access to several peeps with 3D printers
nick205 - 18/10/23 at 11:25 AM
russbost
Any specific reason they need to be Mk 3/4/5 Cortina steering column shrouds?
Is that what steering column you've got / are using?
Could you modify shrouds from a more modern (available) vehicle to suit?
russbost - 18/10/23 at 12:17 PM
Originally posted by nick205
russbost
Donor was a MK5 Cortina, I've got some other column shrouds here, but nothing that even vaguely matches up, I guess I'll just have to make something up
nick205 - 18/10/23 at 02:44 PM
russbost
Makes sense.
I recall using a Sierra column in my MK Indy and being glad I'd kept the 2 piece plastic shroud to refit. Getting something else to line up with the scre fittings would have been hard work. No doubt the stalk apertures wouldn't have aligned either.
CRAIGR - 18/10/23 at 04:58 PM
Any good Russ
https://www.ebay.co.uk/itm/385662076930?epid=0&hash=item59cb404802:g:ricAAOSwJeJkfjn0&amdata=enc%3AAQAIAAAAwMXua2nEXFoM0LS995UjMe%2BWWaaje7lBc 8UqwbC%2FtHsh7tPhpedurtUJjA7c1k5vaA70yPa%2B5BUEW2f%2FqUPb69LdnLUocd8x6%2FNCeOrwRxmfpRgURe3TZTl7%2BBXwGemk4I95kAtoJEbqVM14XuvdhpiHISfAg9bIDWYMrFA7ASSJH QhJLe0Xm1ilgxYfX8luOiNN3UxiG9B4ocdesWW5OZ%2FUnjvDNCoL2t2ypSyxzp41sTla%2BmKvrTbeSEP3d4owfg%3D%3D%7Ctkp%3ABk9SR4aewbvoYg
