Lathe
Daf - 25/5/11 at 07:50 AM
I’m after a little advice, I’ve wanted a lather for years and looked into it many times but never actually gone through with it.
I have been offered the following lathe for £400, it is a Dalton. Other than that and the picture I know very little else about it.
Has anyone any comments or advice? It would be much appreciated
Regards
AdamR - 25/5/11 at 08:01 AM
Some info on lathes.co.uk, but this looks like a later model.
The only thing I know about my lathe is that the company the made it went out of business in 1938! Old tools are cool.
Daf - 25/5/11 at 08:12 AM
So I would imagine spares are hard to come by for you!!!
Good link with some usefull info - thanks
Tris - 25/5/11 at 08:25 AM
Its got an independently adjustable 4 jaw chuck which is nice, which also looks huge.
What's the through chuck diameter ?. Price wise, new for something of the same size your looking at £800 - £1000, so your in the right ball park
owelly - 25/5/11 at 08:32 AM
Check for wear in the controls and headstock. Its an old critter but in my book, old machines are good!
I've just noticed the chuck is mounted on a face plate. Not ideal but what other clobber is included?
[Edited on 25/5/11 by owelly]
Daf - 25/5/11 at 08:36 AM
I have no idea what the diameter of the chuck is, I'm hoping to go and see it next week to decide if I want it or not.
Should I be on the lookout for anything in particular?
What is not ideal about the chuck being mounted on a face plate? Does this cause some sort of probem?
[Edited on 25/5/11 by Daf]
David Jenkins - 25/5/11 at 08:48 AM
It looks like a useful bit of kit - good for learning how to use a lathe, and probably substantial enough to do useful work.
It's got a 4-jaw chuck, but a 3-jaw is also useful.
Chucks usually have their own dedicated mounting plate - this is (usually) a cast iron disk with a threaded connection to the headstock spindle, with the other side turned to fit the back of the chuck. Once this plate is bolted to the chuck then it stays put. If the lathe chucks don't have these then castings can be bought and machined to do the job (I've done 2 for my old Zyto lathe). It would be an excellent first project!
Make sure that the lathe has a full set of change wheels (these go at the left side of the headstock, and various combinations are used to set the speed that the carriage moves across the work). It would be very hard to replace any missing ones.
daviep - 25/5/11 at 09:10 AM
Doesn't look to have a screw cutting gearbox (aka "norton box" ) so you need a full set of gears (aka "change wheels " ) to change the ratio of the lead screw to be able to cut threads, the 127 tooth wheel is very important as this is required to cut metric threads, so if you want to cut threads check these carefully.
Not being able to the lead screw speed also means you'll probably do most of your cutting manually (or at the wrong travel speed) which sounds fine but soon gets boring on long cuts or when roughing.
Also isn't a gap bed model, so the amount you can swing is restricted by the bed, you won't be able to fit discs or drums over the bed.
Looks to be single phase which is a bonus but I think you may have lost the reversing capability which isn't a show stopper but can be a pain now and again.
Chuck being on a face plate isn't a problem but the further you move away from the headstock the more noticable any slack becomes and getting a good finish becomes harder.
How much tooling is included? Tools soon start to add up to a lot of money if you have to buy them and you'll need a few different shaped tools if you want to make anything more complex than a punch or clutch alignment tool. Things like steadies and centres are also handy.
I would be looking for something with a few more bells and whistles personally but it all depends what you want to use it for.
Davie
[Edited on 25/5/11 by daviep]
daviep - 25/5/11 at 09:16 AM
3 jaws chucks are indeed very useful, we use ours as a door stop
Daf - 25/5/11 at 09:18 AM
Can you elaborate on this?
"Also isn't a gap bed model, so the amount you can swing is restricted by the bed, you won't be able to fit discs or drums over the bed."
Went over my head a little
daviep - 25/5/11 at 09:33 AM
A gap bed lathe has the last 6 inches or so of bed missing under the chuck so that you can swing larger items if close to the chuck.
Swing does look quite useful but it's hard to tell from the picture.
Davie
David Jenkins - 25/5/11 at 09:35 AM
Look at the lathe bed, where the tool-slide slides left and right - you will see that the bed goes right up to the headstock. On bigger lathes the bed stops some way short of the headstock - a gap - allowing bigger pieces to be bolted to the faceplate.
I wouldn't get too hung up on that though. This is a model-maker's lathe that would be ideal for learning how a lathe works. Once you get the hang of things, and made the inevitable mistakes, then perhaps you can think about something more advanced.
I paid £50 for my first lathe - it was knackered, some aspects work oddly, but I did learn a lot while fettling it and making it work properly. If this one isn't too worn out then it could be a good first lathe.
tilly819 - 25/5/11 at 09:38 AM
Davie
it means that there isnt a removable secton of the bed (the 2 rails that the tool post carrier/crossslide and tail stock slide on) on some machnies there is a removable section under the chuck so that you can fit (swing) a larger work peice
hope this helps
tilly
^^ beat me too it
[Edited on 25/5/11 by tilly819]
Daf - 25/5/11 at 09:41 AM
Some cracking advice guys, many thanks. I will go and see it before I commit myeslf to anything.
I get the impression it is very important I check for wear. Is there any components in particular I should be checking for wear? If so how much is classed as acceptable?
daviep - 25/5/11 at 09:41 AM
What kind of work do you intend to do with a lathe?
Davie
Daf - 25/5/11 at 09:49 AM
Davie
Make some circular stuff!
There have been various things I've had made like small collars and shafts etc. I've seen lathes used for milling small parts in the past and quite fancy a go at this also.
There's nothing specific I want to make right now but there have been many occasions when I've thought it would be usefull to have a lathe.
