wideband
beaver34 - 14/12/10 at 08:51 PM
hello,
im after a wideband sensor to set my carb in my vw campervan want to be able to do it myself, is there anything out there that isnt £200 that i can use? or is it a case of getting a aem setup or the likes
thanks
BenB - 14/12/10 at 09:26 PM
Triggerwheels.com have some of the cheapest ones out there. Less than £200 certainly....
will121 - 14/12/10 at 09:58 PM
may not be the best way but i set my zx6 carbs up with a narrow band sensor and a diy LED indicator of ebay (bit like one in link below), seemed to be close enough to pick up changes in differet jets sizes and mixture readings
narow band LED sensor
[Edited on 14/12/10 by will121]
prawnabie - 14/12/10 at 09:59 PM
I can get the Bosch sensor for £60 inc post
Breaker - 14/12/10 at 10:01 PM
I already have a wideband sensor. Does someone knows a cheap source for the electronics, perhaps DIY ?
RazMan - 14/12/10 at 10:18 PM
Originally posted by beaver34
hello,
thanks
Do you mean just the sensor or sensor + gauge? The Innovate kit is probably the best value for money and they are available for £140 on eBay IIRC.
robocog - 14/12/10 at 10:23 PM
DIY I did the JAW wideband and it seems to be OK (and was my kind of price!)
I think trigger wheels were doing his latest design though not sure if they do it in DIY kit form?
Regards
Rob
MikeR - 14/12/10 at 10:55 PM
He no longer does the JAW, he's improved the design and now sells it both assembled and DIY (ish).
You need to go to his website which is ....... www.14point7.com and triggerwheels.co.uk resell one of his solutions in the uk.
atspeed racing - 15/12/10 at 08:12 AM
Be carefull buying Innovate from Ebay stores. Innovate will not honour any warranty on units purchased this way according to there website.
matt_gsxr - 16/12/10 at 11:17 PM
If you buy Innovate LC-1 then these guys were the best value when I bought mine.
http://www.maperformance.com/innovate
$189 although there is some postage and import duty.
Matt
prawnabie - 16/12/10 at 11:36 PM
Thats pretty much illegal isnt it? Ive have 2 items repaired by them under warranty that I have bought from ebay as duffers for pennies. The only thing I can remember being stipulated is that f they couldnt repair then I was not entitled to a refund as I didnt by them direct.
