Diagnose this?
Fred W B - 16/4/10 at 04:58 PM
My daily driver has started doing something strange. If the car is running, with the lights on, and I turn the ignition off, the car keeps running, until you turn the lights off, when it then stops.
With the lights off it stops as normal.
It's a 1996 Opel/Vauxhaul GSI - 1800 single cam fuel injected.
I haven't had a look yet, but maybe someone has a clue for me?
Fred W B
mangogrooveworkshop - 16/4/10 at 05:02 PM
has it got a diode thats leaking power back to the ignition circuit
dave1888 - 16/4/10 at 05:12 PM
What he said probably.
scootz - 16/4/10 at 05:17 PM
What they said... probably.
david duncan - 16/4/10 at 05:29 PM
Have you changed bulbs latlely?
BenB - 16/4/10 at 05:44 PM
I'd also reckon a power leak to keep the ignition circuit live.
t16turbotone - 16/4/10 at 05:55 PM
Yep.....beleive it or not a faulty light bulb can cause this! along with bad rectifier circuit (alternator) or bad hazard switch
norfolkluego - 16/4/10 at 06:23 PM
Arrrrrgh
It's the ash, it's the ash, it's coming
Run
hillbillyracer - 16/4/10 at 06:58 PM
My Mk2 Golf would do a similar thing, if you had side lights & an indicator on you could take the keys out & leave it running.
The ignition switch went wrong a while after I noticed it & after a new switch was fitted it stopped it.
zetec mike - 16/4/10 at 11:12 PM
Some of the vauxhalls of that era used to have a dim dip relay that caused exactly that. Cant remember which model, poss cavalier but it was in the offside kick panel.
Fred W B - 17/4/10 at 08:58 AM
Thanks for all the reponses Guys
Well done that man - This morning I found it had one filament in a taillight bulb out, changed it, and the problem is gone.
Locostbuilders.co.uk is the ONLY site you need!
Fred W B
