99 R1 clocks
daryl - 20/5/12 at 11:14 PM
Hi my Mk Indy r1 has been off road for a few year due to buying a house starting to get car sorted back on the road came across a problem the clocks keep doing like a self dino every 15 20 seconds What a mean by self dino when you first turn Car On the rev conter starts at bottom of rev counter to red line it keeps doing this on tickover like a say every 15 20 seconds any help would be very gratefull thanks.
designer - 21/5/12 at 06:54 AM
Don't understand. You need a few full stops and commas in there!
What's 'dino'?
Do you mean the gauges are 'pulsing' (flicking their full range)?
All the clocks, or just the tacho?
Fieldy - 21/5/12 at 01:51 PM
Makes perfect sense...
The R1 clocks have a diagnosis thing built into them, if its going up and down its normal indcative of a fault. The needle should stop at a certain point, this indicates the fault
Your tach will display 3 different diagnostic codes. They cycle every 6 seconds. you can safely run your engine w/the diagnostic code displaying. the engine codes per the service manual are as follows:
3000 rpms: throttle position sensor
7000 rpms: exup related
8000 rpms: fuel level indicator light
[Edited on 21/5/12 by Fieldy]
