Hi, a bit fed up here. Wondering what do check and in need of some ideas.
My heavily used dishwashers main pump crapped out, didn’t stop but just kept stalling, generally falling apart. So I got another pump which is meant
to be a better one. Now every time the machine starts it trips the house breakers! I find it a bit odd as the motor has no earth, is not wet and I put
an ohm’s meter on it and could not seem to find a “leak” for all I can tell. It spins freely and looks in perfect condition but runs for only 1 second
before going off. The drain cycle works just fine btw, its only when it switches on the main pump there’s a problem. I disconnected the heater in case
it was that but still tripped. Was about to cut off the factory plug and replace it with a new one.
Any ideas?? thanks
Rubber gloves ?
Im no electrician, but it sounds like its either stalled, or demanding more current than it can get, is it worth plugging it into another circuit with
an extension lead just to try out another circuit
Originally posted by steve m
Rubber gloves ?
Im no electrician, but it sounds like its either stalled, or demanding more current than it can get, is it worth plugging it into another circuit with an extension lead just to try out another circuit
~Wrong type of breaker, if I remember right there are ones that don't break on surges, more sustained current.
Quick google suggests this:
A Type C device may be substituted for a Type B device where unwanted tripping persists.
[Edited on 25-5-21 by ken555]
Hang on a moment.
Is the RCD tripping or the overcurrent breaker?
I expect the circuit the dishwasher is plugged into is on a 20, or more likely 32A breaker. If the motor is tripping a 20A breaker in a second, te
surge current is over 50A (I could look it up, but you get the idea) If that is the case, the motor is faulty.
Dishwashers are earthed, usually to the metal chassis. So I would expect the motor to be earthed somewhere. But if the RCD is tripping, some
electricity is escaping to earth, causing the RCD to trip. Again, motor is faulty.
Changing the plug won't affect anything.
(I do PAT testing in stacks of student houses, but even that doesn't always show faults. You don't get an earth leak until the main pump
kicks in, but that doesn't happen when the tester is plugged in.)
You could be brave/stupid, remove the earth, and the measure the voltage between the dishwasher and the house earth when it is running. But I
wouldn't recommend it... could be the end of you.
So I replaced the plug and the flex had a dent in it. That seemed to get the machine running fine, for like 5 mins! then it just trips the breaker
again. It's not the individual circuit breakers but the big main one that's switching off the whole house! I don't know what type it
is. It has not blown the 13A fuse in the plug.
The pump itself does not have a earth, there's only 2 connections, I've basically done this conversion -
Youtube Linky. There is an earth wire which is connected to the heater casing & the frame
of the machine but does not go to the motor. I'm wondering if the salt in the soap is now earthing the fault and that's why it ran fine at
first...?
There is a small drip out the bottom of the new pump, it's not clear where that's coming from, I have put a plate under it! and now the
machine is full of hot soapy water The controls are very basic as is the machine.
[Edited on 25/5/21 by Mr Whippy]
Those permanent magnet pumps are sh*t, I eventually got fed up replacing them under warranty and advised customers to bite the bullet and replace the
DW for under £200 and take out a 5 year warranty.
I should add that I repaired Domestic Appliances for over 45 years, until I retired 2 years ago. We purchased a Curries Essentials DW for less than
£200 two years ago with an extended warranty.
So I replaced the plug and the flex had a dent in it. That seemed to get the machine running fine, for like 5 mins! then it just trips the breaker again. It's not the individual circuit breakers but the big main one that's switching off the whole house! I don't know what type it is. It has not blown the 13A fuse in the plug.
The pump itself does not have a earth, there's only 2 connections, I've basically done this conversion - Youtube Linky. There is an earth wire which is connected to the heater casing & the frame of the machine but does not go to the motor. I'm wondering if the salt in the soap is now earthing the fault and that's why it ran fine at first...?
There is a small drip out the bottom of the new pump, it's not clear where that's coming from, I have put a plate under it! and now the machine is full of hot soapy water The controls are very basic as is the machine.
As it's only happening after 5 minutes, it must be either water seeping out and taking that time to get to something electrical or something
switching on at that point (heater or drain pump).
As for getting rid of the water that's in the machine - pull the machine out and to your back door, keeping the drain hose high, then put the
drain hose out of the door and lower it right down and it will drain.
If the pump died the heater element might well have over-heated and fused in which case you'll get an earth fault current when the heater switches on. Can you temporarily disconnect the wires going to the element (make sure you wrap them in insulation tape to prevent a short)? Then run the dishwasher and see what happens....
Yes the big breaker has a test button, it's the only one that goes. I did try disconnecting the heater before but nothing changed, good
suggestion though. I guess it's earthing between the motor and the heater seeing their so close. Damn annoying I thought I had it sorted. Still
dripping water.... Thanks for the advance. I need to take the pump off now and send it back.
Cheers.
RCD's do wear out, especially if they have constantly tripped out, or /and been tested regularly
I changed two in my Daughters house just for this reason,
Gave up on the machine as its over 10 years old and have just got an almost new Bosch one from Gumtree for £100, works perfectly
Thanks for the help. Sending the duff motor back for a refund...
Ive never paid more than £160 brand new, and last a few years. then throw away
Mine was £180 and has been operating for 10 years, so far it's lost a control board which cost me 45 quid - I probably won't be able to get
replacement parts soon anyway
Good choice, make your life simple. I've started to realise my time (and mental health) is worth more than saving a few tens of quids!
