Hello,
I've got this regulator on my Fury, can anyone confirm the means of adjustment?
I'm assuming that it's something to do with the nut on the top? lock nut with adjustment underneath?
Tim
Well, two points. Unless I'm very much mistaken you are missing the manifold vac feed from the top (brass nipple) so your injector pressure differential isn't maintained with changes in manifold pressure, and the way you adjust it is a small set screw sat under the chromed cap nut next to the brass nipple. Clockwise gives more pressure usually.
with my gsxr TBs there are vacuum outlets and hoses from each TB, which join together, i guess to equalise pressure across them. That looks like a malpassi FPR sold as "power boost valves?" don't know whether they are suitable for carbed setups but i have used one on an injected zetec before. Ideally you'll want some sort of guage to measure the fuel pressure, and ideally a probe in the exhaust for air fuel ratio.
Indeed you'd need a feed from all of the throttle bodies if you're running ITBs, you need the combined average of all of them.
What ECU are you running? If it's been mapped like that then leave it but if it was mapped with the correct vacuum feeds maintaining pressure
you'll end up running rich at high load.
What ECU are you running? If it's been mapped like that then leave it but if it was mapped with the correct vacuum feeds maintaining pressure you'll end up running rich at high load.
the vac pipe is conected if your engine is maped to run verible fuel pressures to manifold vac.
some people go fixed and others go verible (std production cars usualy go verible tuners go fixed)
think of it as pressure diffrence between the fuel in the rail and air inside the manifold in low throttle openings the high vac is pulling more fuel
at the injector than if the throttle is wide open when the pressure is near atmoperic so we ajust fuel pressure at the same amount as manifold
pressure to cancel this effect.
if a ecu was maped to run fixed fuel pressure then we dont need to worry about it as its built into the values in the map.
you would pick this up by rich mixture at low throttle openings etc.
oh and i think the ajustable bit is at the dome nut end.
slacken off the dome nut and ajust the nut under it to ajust main pressure up or down.
3 bar is the norm iirc
