Rings stuck in
madteg - 21/10/12 at 09:05 PM
How do i get rings out of pistons when they are stuck in solid, looks like its carbon that is holding them.Thanks Kev
steve m - 21/10/12 at 09:10 PM
I can not say this is the right thing to do, but i have cleaned up some pistons ready for a winter build with Thinners
initially it was just to clean the varnish type of stains of them, but it freed up the rings as well
DIY Si - 21/10/12 at 09:13 PM
I cleaned my KLV6 pistons in paraffin to get me going
ReMan - 21/10/12 at 09:18 PM
coke (acola)?
austin man - 21/10/12 at 09:18 PM
soak in diesel or parrafin thish should soften the carbon, the rings will need changing when you remove them, they will probably break as ther become brittle
perksy - 21/10/12 at 09:28 PM
Turn the pistons upside down and leave them to soak in a container in some parafin
owelly - 21/10/12 at 11:15 PM
I've always found rings to be brittle when new and bendy once used....
Daddylonglegs - 22/10/12 at 08:16 AM
If they are that seized in then personally I would buy new ones, so doesn't matter how you get the old ones out
But if you really do want to get them out, then do as above, but try a few minutes with a blow torch first, that has worked for me in the past, then just a gentle tap to get them moving.
Rob F - 25/10/12 at 04:56 PM
paint stripper dissolves carbon very nicely
