Ford V6 compatability help...
r1_pete - 16/11/18 at 07:19 PM
Can anyone tell me,
Are the engine - bellhousing bolt patterns the same on the BOA / B engines and the 3.0L Essex V6?.
Thanks.
Pete.
[Edited on 16/11/18 by r1_pete]
slingshot2000 - 16/11/18 at 07:33 PM
I am sure they are all the same, but I bet Burtons website will give you a definitive answer;
https://www.burtonpower.com/
If you cannot find the info online, I am sure they will be able to tell you via a phone call, their staff are very friendly and knowlegable
[Edited on 16/11/18 by slingshot2000]
mcerd1 - 16/11/18 at 09:54 PM
No the cossie v6's are cologne based that are totally different to the Essex v6
snapper - 18/11/18 at 01:45 AM
Bellhousing for Essex & Cologne are the same pattern
You can fit Type 9 which has removable bellhousing or MT75 which is built in
V6 bellhousing are different to inline as are the gear ratios and input shaft lengths, the top 2 bolts closer together than inline bellhousing.
r1_pete - 18/11/18 at 12:31 PM
Cheers guys,its for a Scimitar, I intended doing a V8, but, bought a car with interesting history, so thinking about a better engine which doesn’t involve cutting the car.
If the Cologne is the same bell housing pattern, my best option I think is an injected 2.9.
rusty nuts - 18/11/18 at 02:25 PM
PPC magazine have been doing a similar conversion if that's any help?
big_wasa - 18/11/18 at 06:12 PM
Aj30 would be better
snapper - 21/11/18 at 08:32 PM
The 2.9 V6 used by Oval Superrods uses a a 38DGAS on a modified manifold and I’ve seen 200bhp and similar ft/lbs which ain’t bad.
The Granada Cossy 2.9 would also be a good base
Good luck with the build
scimjim - 22/11/18 at 01:20 PM
Originally posted by snapperBellhousing for Essex & Cologne are the same pattern
Bellhousing for Essex & Cologne are most definitely NOT the same pattern.
MikeRJ - 23/11/18 at 06:26 PM
Ever have that feeling of deja vu?
alfas - 23/11/18 at 08:54 PM
can confirm...essex and cologne do not share the same bolt pattern.
an interesting upgrade, still remaining the cologne bolt pattern, is the 4.0L ford explorer engine
