<<  1    2  >>
Author: Subject: Sierras are hard to come by, alternatives?
Ninehigh
posted on 9/2/09 at 09:50 PM Reply With Quote
Not seen a Sierra for sale round here since shortly after coming to this site, does anyone know if they're common in dismantler's places or if there's a common alternative i.e. could I extend a BMW/MX5/Merc one?
RichardK
posted on 9/2/09 at 09:57 PM Reply With Quote
Have you tried searching for p100 's? sometimes they slip by the casual browser.
Rich
Gallery updated 11/01/2011
LBMEFM
posted on 9/2/09 at 10:07 PM Reply With Quote
Sierra's are unsurprisingly, due to their age, getting in short supply. I am surprised that manufactures continue to base their kits on them and don't move on to the latter model cars for doners such as the Mondeo etc.
catman
posted on 9/2/09 at 10:12 PM Reply With Quote
i think they are front wheel drive so no good!
Ed
caged supersix
Carbon/GRP
210 bhp silvertop
190 lbft
Volvorsport
posted on 9/2/09 at 10:13 PM Reply With Quote
volvo
www.dbsmotorsport.co.uk
getting dirty under a bus
jacko
posted on 9/2/09 at 10:17 PM Reply With Quote
BMW
Humbug
posted on 9/2/09 at 10:18 PM Reply With Quote
Jaguar
TVR
Aston Martin
;P
minitici
posted on 9/2/09 at 10:21 PM Reply With Quote
MX5
blakep82
posted on 9/2/09 at 10:46 PM Reply With Quote
Originally posted by Humbug
Jaguar
TVR
Aston Martin
;P
bugatti veyr.... er no?
________________________
zilspeed
posted on 9/2/09 at 11:18 PM Reply With Quote
Mid engined car with front wheel drive donor.
The writing's only been on the wall since 1993 (the year the Mondeo replaced the Sierra).
Build a Sylva Riot and be done with it.
mcerd1
posted on 10/2/09 at 08:20 AM Reply With Quote
granada's and scorpio's can be a bit easier to find, but it wound be nice if more kits moved on to newer donors
Ninehigh
posted on 10/2/09 at 08:29 AM Reply With Quote
So pretty much any rear axle will fit?
It is a problem basing cars on increasingly rare donors, but surely there's another out there that is just about the same width...
mcerd1
posted on 10/2/09 at 08:36 AM Reply With Quote
It all comes down to which design you follow / kit you buy and how much you want to alter it to suit different running gear
a sierra with 7"diff, should be the easiest - other donors might need you to be a bit more creative
Ninehigh
posted on 10/2/09 at 08:46 AM Reply With Quote
Ok when I said `fit`I meant being the same width... How wide is the Sierra diff anyway?
mr henderson
posted on 10/2/09 at 09:21 AM Reply With Quote
Are you seriously trying to find a different donor because you can't find a Sierra, or do you just fancy building something different.
I can guarantee you it will be a lot easier to find a Sierra and base your build on that than it will be to base your build on a different donor, unless you use a kit such as Westfield or MNR do based on the MX5.
If you are planning to build your own chassis then using any donor other than a Sierra is going to take a long time and be more expensive.
Better to drive 500 miles to find a Sierra than start a scratch build based on a different car.
John
posted on 10/2/09 at 09:23 AM Reply With Quote
There not that rare, thousands still on the road and a quick look at ebay theres 45 just searching for Sierra. Some are mega money Cosworths but there are some very cheap ones including a couple of 4x4's.
Ninehigh
posted on 10/2/09 at 09:37 AM Reply With Quote
Actually I was more asking if I could just get the diff really?
mr henderson
posted on 10/2/09 at 09:40 AM Reply With Quote
I expect so. They come up on here sometimes.
mcerd1
posted on 10/2/09 at 10:41 AM Reply With Quote
there are always some on ebay linky
but the prices can be silly sometimes
btw there are 2 sizes of sierra diff 7" and 7.5" (the 7.5" is quite a bit bigger / wider / heavier)
the 7" is the one in most sierra's and is the one most kits are built for (although some kits like the dax's can have either without any mods)
the 7.5" is the most common in the granada's and scorpios, but it depends on age, model, engine and what ford had in the parts bin
[Edited on 10/2/09 by mcerd1]
Ninehigh
posted on 10/2/09 at 10:56 AM Reply With Quote
Ah of course the diff doesn't include axles...
mcerd1
posted on 10/2/09 at 11:25 AM Reply With Quote
so you'll need hubs and driveshafts too then (also on ebay or sometimes on here)
there are 3 types (to suit different diff versions) push-in, bolt-on and cossie 2wd (i.e. bigger bolt-on)
it is possible to get all the bits you need seperatly, but it will probably cost more
mcerd1
posted on 10/2/09 at 11:27 AM Reply With Quote
also some of the BEC lot were using freelander rear axles (lighter than sierra)
mangogrooveworkshop
posted on 10/2/09 at 12:32 PM Reply With Quote
Rich
very different transit bolt pattern
Ninehigh
posted on 10/2/09 at 01:28 PM Reply With Quote
I'd rather it be more expensive than have it sat in the garage rotting because I can't get some rusted piece off
mr henderson
posted on 10/2/09 at 01:45 PM Reply With Quote
I don't think you are making yourself very clear.
Is it the entirerear end you want (with subframe), or a diff, or just the diff and driveshalfts? Or the hubs as well? What about the rear suspension (remember most rwd cars have struts)
If you can say a bit more about what you have in mind the answers might be more helpful
John
<<  1    2  >>
