<<  1    2  >>
New Topic New Reply
Author: Subject: Oxy Acetylene Welding
stutz
posted on 26/2/04 at 03:24 PM Reply With Quote
I Started a night course in welding yesterday(I've welded a bit before, but am fussy and want a chassis I can trust), and the first module is Oxy Acetylene Welding. After discussions with the teacher, and a few searches of this and other forums, I'm considering using this method to build my chassis. I know it will make the job slower, but am more concerned with the overall finish and quality of the job. I'm looking at buying an Oxy Acetylene kit and rang my local BOC dealer who quoted rental of the smallest capacity bottles (3ft Oxy and 2ft Acet) at £70 per year, refill is £40. Sounds a bit expensive to me, has anyone got experience of what I should be paying.
Thanks,
Stephen
[Edited on 27/2/04 by stutz]
blueshift
posted on 26/2/04 at 04:06 PM Reply With Quote
iirc you get major heat distortion problems with oxyacetylene welding. This is enough of a problem with MIG for those of us fairly new to it.. and besides the bottles you have to shell out 200-300 quid for the oxy equipment. Compare that to 150 ish to get set up on MIG..
It's horses for courses, if you were an experienced oxy welder then fair enough, but if you're new to it you might have problems with distortion. Having a straight true chassis is very important for handling.
ned
oxy acetaline will be slower and may well distort the tubes more due to the duaration of higher temp when welding. I found it easier when i learnt to weld but imho mig is the way to go. rental on a bottle of argoshield for mig is similar money. the alternative is the disposable bottles (for mig welding that is)
i'm not a qualified welder, but am sure someone will be along shortly with more info/better arguements.
Ned.
beware, I've got yellow skin
Alan B
posted on 26/2/04 at 04:46 PM Reply With Quote
Originally posted by blueshift......It's horses for courses, if you were an experienced oxy welder then fair enough..........
I agree....MIG is cheaper, faster, easier....
not necessarily better...all methods of welding can do a good job if done right...
Just my 2p
Dave J
posted on 26/2/04 at 04:59 PM Reply With Quote
Hi Stephen,
Is that trade or retail? , per cylinder or for the lot?.Unless you can get a discount, I guess you will be stuck with it. We are paying slightly more on the acetylene, but then it is a 4ft bottle (size F). The oxygen(5ft..size W) works out at £32.00/year rent .No idea what the refil costs.
We also have a MIG set that has a size X (3ft but smaller dia than oxy and acetylene) argoshield cylinder. The rent per year for this is £26.37 all the above do not include Robbin Tax.
I'm just wondering what the difference in costs would be; MIG versus Oxy-acetylene.
Torch, nozzles, flashback arrestors 2 lots of gas etc. I would think that on those sizes of cylinder you may need a few refills (certainly on the oxygen) with he best will in the world, you may have to redo a few welds.
You might think about delaying your decision until you've had a go at MIG welding on your course, then you will wonder why you ever considered gas welding. MIG is sooo easy and quick and in no time at all you will be producing professional welds (Mig doesn't blow back at you either and melt your barnet in a shower of sparks.)
On the safety aspect, personally, I wouldn't fancy storing Acetylene at my home (assuming that is where your build is) heaven forbid if the lot went up, then your insurance Co might come over all awkward.
Best of luck.
Dave
Alan_Thomas
posted on 26/2/04 at 06:05 PM Reply With Quote
I used Oxy to weld all my chassis. Plus points are:
you don't need to pickup the grinder the welds are finished perfectly
also you see the weld pool progressing you know you have full penetration.
Minus points -
Its expensive
Its Dangerous, unless you know what you are doing (MIG never blew up anyone's house!)
It is slower (but warmer in winter)
Unless you are very careful you will get a lot of distortion
So unless you have experience (I had 20 years worth) my advice would be to stick to MIG
Hugh Paterson
posted on 26/2/04 at 06:42 PM Reply With Quote
Steven, + and - on both counts for neatness of welds, the oxy/acetylene wins hands down but as mentioned heat distortion will be a problem especially on thin gauge metals, however if you have a cutting torch as well as the welding nozzles its a damn handy bit of kit for profile cutting lumps of steel and helping stubborn bolts and things free. In a commmercial situation such a setup would be indespensable, in a one off build u can probally do without it in favour of a good MIG setup. No matter what u choose avoid the small bottles of any gas works out more expensive in the long run, (unless u know a nice person in the pub trade for Co2). Another thermal welding technique to consider is Tig, slower than Mig granted but with a bit of practise well worth the effort. Setup costs similar to Mig, quality of welds far superior IMHO. Check with your lecturer to see if u can try a bit of all of them and make your own mind up
Shug.
stutz
posted on 26/2/04 at 06:58 PM Reply With Quote
Thanks for all the replies. I will be going on to MIG and TIG, and wont make my descision until having tried them all. I have done some MIG and ARC welding before, but found the gas welding on my first night far better than any other welding I had done.
Interestingly enough, the school (College of Norh West London) were quite persistant I did gas welding first, as they said it would greatly help my electrical welding later on.
Retail price for both bottles.
posted on 26/2/04 at 07:41 PM Reply With Quote
You will also be hit with a handling or administration charge by BOC. This was £11 per transaction even if you fetched your own bottles from their depot. This is for one or 100 bottles so if you only have one to fill it works out very expensive. I used a portapak kit which I still have but the mig has rendered it unused for a long time now. It was very useful for seized parts though.
yours, Pete.
Stu16v
posted on 26/2/04 at 07:50 PM Reply With Quote
Ahh yes. The Red and Blue spanner....
I also had had access to MIG and gas (and more recently TIG), but I feel that MIG is probably best suited to the chassis construction, for the reasons listed above.
Stutz, the tutor is on the ball (well, he should be really...). Once you have mastered gas, the rest will follow almost naturally. MIG is like drawing slowly with a felt tip pen (subject to correct setting), and TIG is kinda like a mixture of the two skills. All have their strengths/weaknesses.
Mark Allanson
posted on 26/2/04 at 10:16 PM Reply With Quote
Hey, Guys, you are getting me all nostalgic, I love Sexy Ahotalene, The distortion problem is no real problem as, the same with MIG, you will be welding both sides of the tube so the distortion should cancel themselves out.
Advantages are that if you do get a bit of distortion, you can just heat up the tube to either expand it or contract it using the cutting nozzle without the trigger pulled. It is really useful for bending, unsiezing, making O/A baloon bombs, brazing, soldering, cutting..... it is good fun.
blueshift
posted on 27/2/04 at 02:34 AM Reply With Quote
guh, mark, you're making me think about getting a set again just for funning around with. Stop it, please.
ed_crouch
posted on 27/2/04 at 10:14 AM Reply With Quote
It wont matter about insurance. You will be VERY VERY VERY DEAD.
ed.
I-iii-iii-iii-ts ME!
Hurrah.
www.wings-and-wheels.net
Staple balls
posted on 27/2/04 at 10:21 AM Reply With Quote
rather than just
a little bit dead?
Dave J
posted on 27/2/04 at 10:30 AM Reply With Quote
From a purely practical point of view, oxy acetylene, whilst giving you good welds is awkward in that unless you have a safe custom built stand to rest the torch when moving the tube to be welded about, then you will be forever turning off and relighting your torch.
No doubt like the rest of us, space is at a premium, therefore waving a lighted torch about might be a bit hazardous.
Assuming you have a safe stand to put the lighted torch on, then you have to think about all your expensive gas burning away while you are not welding. At least with MIG the gas only flows when the trigger is activated.
Mind you the thought of having a nice hot welding torch at the moment is quite attractive, its brass monkies to say the least in my garage
Dave
Dave J
posted on 27/2/04 at 11:03 AM Reply With Quote
Assuming you are daft enough to stand around warming your hands on an increasingly heating acetylene cylinder, then yes I'd say you would be pretty much dead.
If anybody does have the misfortune to have a heating cylinder, then provided it hasn't gone too far (too hot to touch), then call the fire brigade, drag the cylinder outside, if you have a garden pond chuck it in. Failing that, hose the cylinder down to keep it cool, until the firebrigade can take over. If it has gone too far, evacuate the area and leg it to a safe distance.......cause you got a potential bomb there.
I've always thought it would take nerves of steel to do this, so I go by the adage "Life before brickwork.......leg it!"
This is what flashback arrestors are for, to make sure this doesn't happen.
If you go for second hand kit, make sure you replace the arrestors with new. It's not worth the risk to do otherwise.
Don't get too alarmed, been doing gas welding for years, not had it happen yet (touch wood)
Dave
posted on 27/2/04 at 11:20 AM Reply With Quote
I must admit that I have fancied a portapac oxy-acetylene setup, but shied away from having these gases in a domestic environment (I consider oxygen a dangerous gas in its own way - nice to breathe in small quantities, but hazardous in bulk!).
If I did have oxy-acet. I must admit that I would probably consider brazing rather than welding - much less chance of heat distortion as it's a lower temp.
Can you use oxy-propane for brazing? I don't see why not, and it would be a lot safer than acetylene.
rgds,
Hugh Paterson
posted on 27/2/04 at 11:28 AM Reply With Quote
The propane is a bit dirty as gas goes but it would chuck out enough heat to braze with, better using it for burning only though in lieu of chucking expensive actylene throw yer burning torch with the oxy. Good hint neat Oxy out a mask is a damn good hangover cure now how would I know that
Shug.
Terrapin_racing
posted on 27/2/04 at 11:43 AM Reply With Quote
Gas welding is fine - don't be put off by the fear mongers. If you are considering using OA then you need to consider the safety aspects. All the information you need is freely available from BOC etc.
Follow the safety advice - use quality flame arrestors etc. I use a small set as mentioned earlier in the chain. Rental is about £80 per annum for the bottles and refills are approx £40 a pair.
It does last a long time and is very flexible - brazing, welding - general heat applications etc.
[Edited on 27/2/04 by Terrapin_racing]
Cousin Cleotis
posted on 27/2/04 at 02:15 PM Reply With Quote
hugh, if you breathed just pure oxygen you will die.
Hugh Paterson
posted on 27/2/04 at 02:33 PM Reply With Quote
Silly I know that it was medicinal out of a "sick bay bottle", nice wee lift if u are hungover, then we all got caught
Shug.
blueshift
posted on 27/2/04 at 03:18 PM Reply With Quote
I think this is untrue.
Hugh Paterson
posted on 27/2/04 at 06:02 PM Reply With Quote
Blue shift I suspect yer right but as I was having a whiff of it along with one of the sick bay Rangers on my ship, I thought in for a penny, doubt if I would snort it out of a welding bottle har har
Shug
flak monkey
posted on 27/2/04 at 06:09 PM Reply With Quote
Yes you can breathe pure oxygen, but not recommended for long periods, see quote below;
Question - Could humans breath (survive) in at
atmosphere containing pure oxigen?
Yes they could...for a while and then they would begin suffering from oxygen
toxicity which causes a number of serious problems not the least which are
some pretty serious neurological damage.
PF
Sure. At normal atmospheric pressure, it's fairly dangerous, as ordinary
substances such as clothing become extremely flammable under those
conditions. In the short term, the human body has no problems with a high
concentration of oxygen. In fact, exposure to elevated oxygen pressures is
sometimes even used as a treatment for some diseases, such as gangrene.
Over the long term, some tissues may suffer oxidative damage. I don't
really know what the long-term health effects are, though.
Richard E. Barrans Jr., Ph.D.
Assistant Director
PG Research Foundation, Darien, Illinois
Give a good head rush apparently
Sera
http://www.motosera.com
Mark Allanson
posted on 27/2/04 at 06:57 PM Reply With Quote
Bugger snifing it, just keep making the balloon bomgs
<<  1    2  >>
New Topic New Reply
