GavR
posted on 12/5/10 at 01:28 PM |
What's your MPG??
What kind if MPG figures do you guys get from your kit car?
I'm running a ford 2.0l zetec blacktop on R6 TBs and I recon I'm getting about 15-20Mpg driving steady!
Anyone got a similar set up to me? If so what's your appox MPG?
Gavla
Richard Quinn
posted on 12/5/10 at 01:30 PM |
Life's too short to check or worry!
flak monkey
posted on 12/5/10 at 01:34 PM |
On the pinto on GSXR600 TBs and megasquirt i used to get around 30mpg on a run and 25 on a spirited drive.
Duratec returns around the same even with the charger strapped on. Will be interesting too see what it is once its set up properly though.
Sera
http://www.motosera.com
GavR
posted on 12/5/10 at 01:35 PM |
Lol I like your view on life but unfortunatly my bank account is too short :p
GavR
posted on 12/5/10 at 01:38 PM |
Thanks David, I really need to upload my megasquirt setup because I'm sure it's using to much fuel. I'm sure someone will spot
something wrong with my data file
StrikerChris
posted on 12/5/10 at 01:40 PM |
92 mile to 27 litres(if someone can work that out) last time we ran out!have to start lookin for a garage every 90miles instead of 100 now!
tomgregory2000
posted on 12/5/10 at 01:41 PM |
sat on the motorway doing between 70 and 80 i get about 30 mpg but i wouldnt like to work out what im getting when i drive it hard
whitestu
posted on 12/5/10 at 01:42 PM |
You need some carbs mate!
I have the same engine on ZX6R carbs and get just under 40 at motorway speeds and 15 ish on a track day!
Stu
[Edited on 12/5/10 by whitestu]
StrikerChris
posted on 12/5/10 at 01:43 PM |
Sorry,think i've just told you,and mine's standard!
GavR
posted on 12/5/10 at 01:44 PM |
30 that's good, mine does about 13mpg on the motorway doing average 70mph I hate motorways! Doesn't help my pocket only using v power
either lol
b16mts
posted on 12/5/10 at 01:45 PM |
on the long run to stoneleigh and back i was knocking on the door of 30mpg. with a 2.0 pinto and fr33 cam.
what get on a proper drive i don't know, dont have time to look at the speedo never mind the odometer!
Martin
who says you can't drive a kit car when you're 6'5"?
tomgregory2000
posted on 12/5/10 at 01:47 PM |
if i can get 100 to a tank when driving hard ill be happy, i was getting 100 to a tank with my red top on carbs sat on the motorway doing 60
flak monkey
posted on 12/5/10 at 01:53 PM |
Do you have a WB Lamda fitted?
If so it will tell you most of what you need to know.
You want to aim at 14.7 cruising and light acceleration. And 12.5AFR WOT. I assume you have mapped using alpha_n and not speed_density.
Upload your msq and I will have a look.
Sera
posted on 12/5/10 at 02:01 PM |
I chased a Focus RS on the way back from Stoneleigh, used an indicated 1/2 tank over 20 miles
I have a 40L tank btw...
GavR
posted on 12/5/10 at 02:08 PM |
Cheers david, I'll upload something tonight hopefully. Look out for a new topic on here called megasquirt fueling problems
Humbug
posted on 12/5/10 at 02:12 PM |
Completely different engine: 1.4 K series on standard inlet and ECU: 37mpg over all types of driving
Madinventions
posted on 12/5/10 at 02:21 PM |
I've got a 1.7VCT Zetec SE from a Puma in a 520Kg Mojo, and I get about 35-40mpg when cruising (70mph is about 3000rpm in 5th). I'll be
going round Snetterton in it next week so I'll let you know what I get then!
Ed
[Edited on 12/5/10 by Madinventions]
View my band website:
http://www.shadowlight.org.uk
Doofus
42 mpg on a round trip to Antwerp.
2.0 Duratec with GSXR TBs.
I didn't include the track day round Zolder though, that might have reduced it a bit
Paul.
posted on 12/5/10 at 02:38 PM |
Low to mid 20s when cruising on the motorway but that is a 5.5k rpm.....
franky
posted on 12/5/10 at 02:50 PM |
A standard m3 does 28ish so should get 35-45 pulling less than half the weight.
GavR
posted on 12/5/10 at 02:57 PM |
Cheers ed, got a 40mile drive from Chesterfield to do 2night so I'll get a accurate Reading 2night. I'd b happy with 20 lol
rallyingden
posted on 12/5/10 at 03:19 PM |
I have gone through two tanks full of fuel ................................... and I've not been off the drive yet !!
RD
[Edited on 12/5/10 by rallyingden]
mookaloid
posted on 12/5/10 at 03:39 PM |
I used to get about 3-4 mpg on a hill climb day
jollygreengiant
posted on 12/5/10 at 03:53 PM |
StrikerChris - 15.488mpg
As for myself, since on the road, average of 25mpg and an 11.8 gallon tank
adithorp
posted on 12/5/10 at 04:10 PM |
I get just under 30mpg on motorway 20-25mpg on a blat and 15-20mpg on track.
Injected R1 by the way.
adrian
http://jpsc.org.uk/forum/
