Dale
posted on 10/6/04 at 02:55 PM |
Way out from the norm question
Propane or lpg. Any considered running this instead of gas, only reason it has even crossed my mind is the 105 octane which would let me run 20lbs
of boost without detonation. (well untill the head gastget blows)
Dale
Terrapin_racing
posted on 10/6/04 at 03:03 PM |
There are some interesting characteristics about propane that make it an ideal engine fuel. First, propane is clean-burning, much more so than
gasoline. Propane leaves no lead, varnish, or carbon deposits that cause the premature wearing of pistons, rings, valves, and spark plugs. The engine
stays clean, free of carbon and sludge. This means less maintenance and an extended engine life.
Also, propane is all fuel. It doesn't require additives usually blended into some grades of gasoline. Even without additive boosters,
propane's octane rating of 110 is equal to and, in most cases, higher than available gasoline.
Propane-fueled engines produce less air pollution than gasoline engines. Carbon monoxide emissions from engines using propane are 50 percent to 92
percent lower than emissions from gasoline-fueled engines. Hydrocarbon emissions are 30 percent to 62 percent lower.
So why isn't propane used as a transportation fuel more often? For one reason, it's not as conveniently available as gasoline. Second, an
automobile engine has to be adjusted to use propane fuel, and the cost of converting an engine to use propane is often prohibitive. Third, there is a
slight drop in miles per gallon when propane is used to fuel vehicles.
http://www.perr.com/tip6.html
[Edited on 10/6/04 by Terrapin_racing]
Noodle
posted on 10/6/04 at 03:23 PM |
I run my Nissan Primera eGT on LPG.
With the installation like mine, I drop about 10% MPG and torque. Also, I've a 100 litre grenade, sorry, fuel cylinder in the boot and the
system works on the basis that's the tanks pressurised and the fuel will find it's way to the lower pressure area (i.e. the inlet tract).
This is passive fueling is all very well, but when you're nearing the end of a tank, fuel pressure can be sufficiently low for you to be left
with 'mild suprise' as the power fades during that demon overtaking manoeuvre.
I've heard various things about the RON being higher, so the power drop would be down to the following reasons?:
1. Slower burning fuel. I doubt this. The car will still rev to 9000 rpm
2. Sh?tty, basic installation kits that are too generic for their own good.
One of the Megasquirt guys in the U.S. was running a MK2 RX-7 on propane ...
http://www.6speed.org/rx7/propane/
Neil.
[Edited on 10/6/04 by Noodle]
Your sort make me sick
splitrivet
posted on 10/6/04 at 03:28 PM |
Ive converted my moped to run on propane,the most important item in the conversion was a 1942 ex MOD frogman kit,this has 2 advantages;
1 With the fuel strapped on my back no one can nick my bike,although I do get some strange looks when nipping round Asda.
2 You are always popular at barbies.
Running on propane is vastly superior to my original idea of running on methane where I had loads of problems with the rectal probe coming out at
speed.
The reason I switched to propane from methane was one morning after an evening of 10 pints of Pedigree and a Vindaloo I found myself on the Forth road
bridge, this was a bit disconcerting as I'd only nipped down the paper shop for a packet of fags and a Mirror
Bob
[Edited on 10/6/04 by splitrivet]
Dale
posted on 10/6/04 at 04:18 PM |
It would make passing emssions testing alot easier and would not have to pay for a cat converter. Just not certain how it would work in a high
pressure fuel injection system.
Dale
type 907
posted on 10/6/04 at 05:29 PM |
Well done Bob, most amusing.
Paul G
Too much is just enough
posted on 10/6/04 at 07:16 PM |
Bob - we like that! Toilet humour in it's lowest form...
stephen_gusterson
posted on 10/6/04 at 08:27 PM |
dont water injection systems increase octane value and allow use of regular petrol.....
atb
steve
Noodle
posted on 10/6/04 at 08:50 PM |
Water Injection
As I understand them, they just suppress detonation by lowering combustion temperature allowing higher boost pressures. They don't bring any
more energy into the equation. Increases in power are a result of the higher attainable boost pressures.
Neil.
paulbeyer
posted on 10/6/04 at 11:40 PM |
As some of you guys on this forum already know I converted my Saab 9000 to run on LPG 3 years ago. The best thing about it?................filling up
at Morrisons for 27.8p / litre
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
stephen_gusterson
posted on 11/6/04 at 09:14 AM |
The govenment have stated for years that LPG will be taxed as heavily as petrol if it catches on big time.
I can fill up anywhere for nothing. Its called a company fuel card. 100k over 4 years motoring, for just a little bit of tax
atb
steve
paulbeyer
posted on 11/6/04 at 10:35 AM |
I had 32 company cars in a 10 year period and averaged about 80k miles a year. It damn near killed me. You can shove your company cars and fuel cards
up your cinnamon ring I'll never do that again.
As far as the government is concerned they are under too much pressure to achieve their commitments to cleaning up the environment. LPG is one way
they can be seen to be doing something positive. Sure the duty on LPG is going to increase over the years but it will be a long time coming before it
gets any where near the price of unleaded or diesel so I'll enjoy the benefits while I can.
sebastiaan
posted on 11/6/04 at 11:40 AM |
Noodle,
LPG tank pressure is only dependant on temperature and LPG composition as long as there is liquid LPG in the tank. What you're talking about is
that vapour LPG gets inside the regulator, thus halting flow (and engine power)
The lower power is caused by the simple fact that on older systems there is a venturi in the intake system to mix the gas. Newer (injection) systems
tend to have less than 5% power loss. There's just the fact that the fuel actually takes up more volume inside the combustion chamber, and thus
leaving less room for air (and thus a smaller bang).
This can easily be overcome by running just a tad more ignition advance though....
As for boost: we run an audi TT on lpg during long distance races as 270bhp, no problems (maximum boost is around 20PSI on standard internals and
gaskets!)
Sebastiaan
Terrapin_racing
posted on 11/6/04 at 11:53 AM |
Used vegetable oil with a dash of kero seems to be the cheapest option these days (if you run a diesel )
I was behind an iveco truck the other day and swear I could smell cod 'n chips
Dale
posted on 11/6/04 at 12:21 PM |
Have any of you heard of someone running a 2.3l turbo ford? with injection-- I would not mind finding some info on one if its out there. Its the
engine from the north american xr4ti.
Dale
Noodle
quote: Originally posted by sebastiaan
Noodle,
thus leaving less room for air (and thus a smaller bang).
gaskets!)
Sebastiaan
Today I've learned something new. Thanks very much Sebastiaan!
Neil.
sebastiaan
posted on 13/6/04 at 06:52 PM |
Don't drive a diesel, you'll kill people!
My preffered "end of the road" setup for the indy would be a turbo'd CBR thou (bulletproof engine!) / blade on LPG. I'll
probably end up with a turbo'd 1.6 pinto though.
LPG in a 7 makes sense to me, as there's room enough in the back for a reasonably sized tank, you've got simple fuel system and it's
cheap as a bonus! SVA would be simpler too, as far as emissions go.
But maybe I just like being different....
stephen_gusterson
posted on 13/6/04 at 10:07 PM |
there were listers on
http:/groups.yahoo.com/group/locost
that did.
also take a look on the north american list. just search on yahoo under locost.
as far as diesels are concerned, uk tax laws are positively forcing company car drivers to go that route.
I could have a 143 hp petrol 3 series for 280 a month, or a 150hp diesel for 175.
no brainer.
atb
steve
Dale
posted on 13/6/04 at 10:20 PM |
its a shame really, cos its the 10 micron soot particles in diesel exhaust that are the real killers. these muppets should realise that the only
'green' way forward is to avoid cars altogether, which isnt practical. So they should accept that our society is on a crash course
whatever we do. Too late to save us in my books.
greggors84
posted on 14/6/04 at 01:49 PM |
My house mate works for Formula Palmer Audi as a mechanic at weekends. We were talking about Jonathan Palmer and how rich he was, and basically its
because hes a good business man. Apparently they run their whole fleet of track day cars (the ones you go and drive for a day at bedford autodrome) on
LPG, it saves them a silly amount of money. If they use lpg in these cars, which im sure includes caterhams and the JP1 (a sort of LMP) it must be ok
for us locosters.
Chris
The Magnificent 7!
paulbeyer
posted on 14/6/04 at 01:57 PM |
I keep telling ya 27.8p / litre makes sense
NS Dev
posted on 14/6/04 at 05:02 PM |
Long story but bear with me!!
During the fuel blockades a few years ago I was supposed to be going rallying in Ireland, and was stuck at my mate's house at kielder in
Northumberland in my Capri 2.8i with 1/4 tank of fuel!! (We were getting the ferry from Pembroke in Wales!!!)
He had a Sierra 2.3 diesel estate with 2/3 of a tank, so we decided to drive it down the 240 miles or so to my house near Hinckley that evening and
try and hatch a plan to get to the docks somehow!!
Got to mine with 1/4 of a tank left, rang another mate who we were to collect at Ludlow but his Pug 205 diesel was nearly empty so no siphoning
opportunities!
Oh dear, no transport, thought about red diesel bought from the farm but we had seen loads of trucks etc getting stopped and dipped so decided against
it!
BRAINWAVE!!! Mum and dad's heating system is oil fired, and it smells just like diesel, a quick phone call to a diesel engineer mate confirmed
that diesels will run on this no problem, just need to add 2-3% engine oil as it is a "drier" fuel than diesel and can wear the fuel pump
quicker if no oil is added. Did this, made up 75 litres, filled up the car to the brim and put one and a half 5 gallon drumfulls in the back and off
we went, got to ireland, followed the rally around and back to northumberland on that lot!! No ill effects either and it passes the dip test cos
heating oil is not dyed, and it cost 19p per litre!!
Nick Davison
posted on 18/6/04 at 02:48 PM |
How do you get it that cheap, I can only go as low as 37.9p litre.
Nick
greggors84
posted on 18/6/04 at 03:07 PM |
We have oil fired heating at home, and i always thought it was the same as red diesel to stop people using it in their cars. Looks red ish on the
level gauge too.
Might have a diesel now, if its possible to use it.
Chris
The Magnificent 7!
NS Dev
posted on 18/6/04 at 05:34 PM |
Better have a look first!! The stuff we had was a yellowish tinge in the level tube, but smelt the same as diesel. Take a dip and have a look, it will
be obvious if it's the red stuff. The stuff we had was very pale, almost clear, sort of pale urine colour!!
