posted on 2/3/11 at 01:12 PM |
WTD: Chassis Baffles
... cash waiting!
It's Evolution Baby!
TimC
posted on 2/3/11 at 01:18 PM |
A what? Sounds like a left-handed screwdriver to me.
posted on 2/3/11 at 01:23 PM |
I've removed all my panels to paint the chassis so it's now full of rivet-ends.
I reckon if I go around a corner at anything more than 30mph, then the car might tip due to all the rivet-ends rushing to one side.
Chassis-baffles should sort it out...
dan_g8
posted on 2/3/11 at 01:27 PM |
what about using wax-oil inside the chassis rails? once dry it should keep the rivet ends still.
posted on 2/3/11 at 01:34 PM |
I would go for the waxoyl approach Dan, but that's heavy... the chassis baffles come in Unobtainium, so they actually make the car lighter.
mads
posted on 2/3/11 at 01:40 PM |
surely all you need to do is create some larger holes in the chassis of your car and the next time you go round a bend, they will all just fall out?!
plus, making those holes will definitely make your car lighter.. simples!
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in
sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
posted on 2/3/11 at 01:49 PM |
I like your thinking Mads, but swiss-cheese style holes may affect the air flow and their presence may attract insects and small rodents to nest
within (again... more weight) so are no use to me.
Nope... it's chassis baffles for this job!
r1_pete
posted on 2/3/11 at 01:50 PM |
How about filling the chassis with expanding builders foam??
deezee
posted on 2/3/11 at 01:54 PM |
Have you tried heating your chassis to 700 degrees, turning the aluminium rivets into liquid.... then you can pour them out? Seems like the most
practical solution.
scudderfish
posted on 2/3/11 at 01:55 PM |
Slice the tops off all the tubes, fish out the ends, weld tops back on.
posted on 2/3/11 at 02:10 PM |
I'd have thought a chap of your calibre would own an ally magnet Scootz...?
Just open one of the rivet holes and apply your ally magnet then draw all said rivet heads out in a dasiy chain.
posted on 2/3/11 at 02:11 PM |
Either that or sell the chassis and get a new one from Procomp
procomp
posted on 2/3/11 at 02:37 PM |
Hi
You can use the rivets floating around as a performance meter. If you can't hear when cornering you ain't going fast enough.
Hole at one end of tube and remove em , then re weld it all back up. Ill sort it when i get the chassis down here if you like.
Cheers Matt
blakep82
posted on 2/3/11 at 03:02 PM |
theres some ships bulkheads laying in fergusons shipyard in port glasgow, maybe that could work?
________________________
kipper
posted on 2/3/11 at 03:19 PM |
chassis holes
Just leave the holes and when the car is whizzing along some deft fingering should produce the flight of the bumble bee.
In bee sharp
Denis.
Where did that go?
mad-butcher
posted on 2/3/11 at 05:19 PM |
I fitted some of those rivet things to the inside of my chassis, great way of keeping rust off the inside of the tubes caused by water ingress due to
pin holes in the joints, problem is being softer than steel they eventualy wear away, if the price is right I may be willing to purchase yours
tony
blakep82
posted on 2/3/11 at 05:25 PM |
just keep filling up the chassis with more rivet ends til theres no room to rattle about
or squirt some kind of glue in there and go for a good twisty drive to rattle them into the glue
posted on 2/3/11 at 05:44 PM |
Some excellent suggestions here! Our pool of chassis-engineering knowledge is deeper than the mariana trench!
posted on 2/3/11 at 05:46 PM |
... sell the chassis and get a new one from Procomp
LOL... already been considered!
dave
posted on 2/3/11 at 06:02 PM |
Make a bigger hole at one end then soooook them ooooot with a vacuum.
ReMan
posted on 2/3/11 at 08:25 PM |
melt some solder and pour it into the tubes so it sticks em fast?
www.plusnine.co.uk
fazerruss
posted on 2/3/11 at 09:29 PM |
Ive got the solution- you need to get hold of some ali eating nanomites like the ones used against the G.I.JO squad. Just make sure you get the
Ali-nanomites and not the Ferro-nanomites or you will have no chassis left. Also remember to deactivate them when finnished with the rivets or they
may eat your wheels!
"if assholes could fly this place would be an airport"
RoadkillUK
posted on 2/3/11 at 09:35 PM |
Drill holes at the bottom back of the tubes and accelerate until the rivets fall out. Oh, then weld 'em up.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
posted on 2/3/11 at 09:48 PM |
I've just checked at my local motor factors... they only have the ferrous-eating nanomites
blakep82
posted on 2/3/11 at 09:54 PM |
thats fine, get those, they'll eat the chassis away, all the rivet ends fall on the floor, then you put a new chassis around where they used to
be, chassis will then be emty of rivet ends. easy
[Edited on 2/3/11 by blakep82]
