<<  1    2  >>
New Topic New Reply
Author: Subject: MK Indy project, early
nilocp
posted on 4/2/12 at 11:06 AM Reply With Quote
I have just bought an early MK Indy project. Chassis is live axle, late 90's, but never built. There are other parts with it, but any tips?
Any insumountable issues with these?
Which bodywork fits?
Is it based on Champions plans?
I will need some parts, so let me know what you have spare please.
Colin
redeye
posted on 4/2/12 at 12:18 PM Reply With Quote
May be the same Chassis as mine then, its not called an Indy due to the live axle
I fitted mine with a pinto engine but had to raise the side of the chassis by adding more box section too the top rails
Im now currently fitting a duratec engine.
You may find the self centering to be a pain, We had to chop my wishbones up to sort this out, but once done it handled like a dream.
My live axle is actualy from a capri too, which gives an extras 2inch either side.
Mk Indy bodywork will fit just fine.
Give me a shout if you want to know anything else
Patrick
MakeEverything
posted on 4/2/12 at 12:24 PM Reply With Quote
Patrick
You had to modify MK components as well??
Kindest Regards,
Richard.
redeye
posted on 4/2/12 at 12:40 PM Reply With Quote
Yeah, the wishbones worked fine except that they just would not self centre, I believe this is common on the mk indy too. but dont hold me to that.
nilocp
posted on 4/2/12 at 01:07 PM Reply With Quote
Redeye, so if it isnt an Indy what is it called?
Problems with self centreing, did you actually do a geometry check on it? Too much caster?
I was thinking of putting rose joints on to adjust caster and camber.
Engine will be a crossflow to start. Just because I have 1 lurking complete with a 5 speed!
Any idea what shock absorber length should be? I have been offered some but not sure what they should be.
Was there any sort f build manual for MK, or is just Haynes?
Colin
ReMan
posted on 4/2/12 at 01:11 PM Reply With Quote
Indy with a live axel Nindy?
Any chance you could post a pic up of it my mate would love to see if it's anything like his
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
40inches
posted on 4/2/12 at 01:23 PM Reply With Quote
Colin
I believe the very early ones are simply a Locost chassis.
MakeEverything
posted on 4/2/12 at 01:58 PM Reply With Quote
Colin
Yes, it came with your angle grinder.
Kindest Regards,
Richard.
redeye
posted on 4/2/12 at 02:37 PM Reply With Quote
The design of the wishbones gave pretty much no caster, so we moved the centre of the wishbones towards the rear. this worked a treat, It was a friend of mine that actually modified them and at the time he didnt have any round tube so just used box section, this worked well but looked aweful so Ive recently had them remade by a locally.
My car was one of the earliest chassis built by Mk long before they started making the Indy and yes its pretty much based on the book. Ive been told it was built in Martin Keenens own garage before he actually started the company, but rest assured all Mk chassis are usually very well put together.
Theres photos of my car in my photo archive if you want to see if its the same style chassis
Its handy that you have the crossflow since this is the engine the chassis was designed for, so you shouldnt have any real problems.
theres no build manual but its not really needed, just use the search function on this site to find all the answers you'll ever need or ask if you cant find them.
Where are you based btw?
Good luck with the build
Patrick
mangogrooveworkshop
posted on 4/2/12 at 02:49 PM Reply With Quote
So it was you bidding against me .............
nilocp
posted on 4/2/12 at 03:27 PM Reply With Quote
Obviously I wanted it more than you!!!....
NigeEss
posted on 4/2/12 at 03:42 PM Reply With Quote
Colin
I always thought it was known as an Mk Locost.
nilocp
posted on 4/2/12 at 03:43 PM Reply With Quote
Redeye, getting back to Shox, have you got any dimensions `please.
Colin
Russell
posted on 4/2/12 at 03:54 PM Reply With Quote
It's just an MK Locost and I've got one. Most are live axle but there are some de-dion.
The Indy came along later.
I'm a bilingual illiterate. I can't read in two languages.
redeye
posted on 4/2/12 at 04:09 PM Reply With Quote
Not sure. Im not near the car at the moment but ill measure them up when I get a chance.
If they are the same as the book chassis then someone on here may be along to tell the lenghs needed though
nilocp
posted on 4/2/12 at 05:16 PM Reply With Quote
I am trying to load a pic, but dont seem to be able to
Is that because I do not have enough posts?
Colin
Bizarro
posted on 5/2/12 at 08:12 AM Reply With Quote
Colin
Probably because the file size is too big, reduce the size to around 300kb and try again..
nilocp
posted on 5/2/12 at 10:46 AM Reply With Quote
Aah, sorry I dont even know how to do it!!!
Bizarro
posted on 5/2/12 at 04:59 PM Reply With Quote
Open picture with 'microsoft office picture manager' (if you have it on your pc!!), at the top click 'edit picture', then down the side you will see 'compress picture', click on this and you will have different compression ratios, choose one about 300kb and 'save'..... Simple...
[Edited on 5/2/12 by Bizarro]
40inches
posted on 5/2/12 at 05:36 PM Reply With Quote
Download Context image resizer then right click on the image and choose the size you want. Simples
nilocp
posted on 8/2/12 at 08:40 PM Reply With Quote
Should be a pic here now!!
CP
nilocp
posted on 8/2/12 at 08:45 PM Reply With Quote
Bollocks!!
It didnt work. That was supposed to be a link to Photobucket.
How do I do this? The pic is only 22kb.
CP
nilocp
posted on 8/2/12 at 08:49 PM Reply With Quote
PAUL FISHER
posted on 8/2/12 at 08:54 PM Reply With Quote
You will get the hang of it
nilocp
posted on 8/2/12 at 09:08 PM Reply With Quote
Thanks Paul!!
Please tell me how you did it!!
colin
<<  1    2  >>
New Topic New Reply
