computid
posted on 2/5/12 at 09:42 PM |
Removing a stubborn oil filter
So, this evening I thought I'd give the minari a much needed oil service. I set to and drained the oil from the sump then moved onto the oil
filter.
So far I've tried:
Undoing it by hand
Using a strap wrench
Using a chain wrench
Using a sealy oil filter wrench
Hammering the sealy oil filter wrench
Hammering a screw driver through the oil filter and trying to turn it.
None of which have moved it an inch. I now have a very holey and dented up oil filter.
Anybody got any ideas? I'm rather stuck as I want to get it changed ready to drive up to stoneleigh on sunday.
Daddylonglegs
posted on 2/5/12 at 09:48 PM |
What the heck did you tighten it up with??!!
Should only be finger tight then a little 'nip up'.
Sounds like you might end up having to destroy the filter and use mole grips or similar?
mookaloid
posted on 2/5/12 at 09:49 PM |
oil filter pliers - these have never let me down yet
computid
posted on 2/5/12 at 09:50 PM |
I didn't tighten it up, the previous owner did and I think it was about 12 years ago. I always tend to fit the ones with nuts on the end to make
it easy to undo then in this exact circumstance!
Daddylonglegs
posted on 2/5/12 at 09:59 PM |
In which case chap I think you ought to pay the previous owner a visit and get him/her to do it
posted on 2/5/12 at 10:02 PM |
Can you get to the lip where it meets the engine to give it a clout with a hammer and chisel ?
MkIndy7
posted on 3/5/12 at 12:03 AM |
Could try 18" stilsons high up on the filter rim should just open wide enough or 24's if not, done the trick for me last few times if
there's some available to you.
T66
posted on 3/5/12 at 05:29 AM |
As previously stated - Hammer and bluntish chisel on the rim, have fun
owelly
posted on 3/5/12 at 05:57 AM |
If the canister bit is completely mashed, cut it off to gain acces to the base plate of the filter and use an angry-grinder wheel fitting tool to
remove it. The base plate should have a ring of holes and the prongs of the grinder tool can fit into one or more of these to get a good purchase.
http://www.ppcmag.co.uk
will121
posted on 3/5/12 at 06:13 AM |
This worked for me, but using an old screwdriver rather that a chisel
jimgiblett
posted on 3/5/12 at 07:56 AM |
With really stubborn filters a good method is to put a jubilee clip around it near the base. Use a ratchet and 7mm socket to tighten up as much as you
can with the screw head on the left hand side. Insert a large screwdriver with a steel shank that goes through the handle into the screw slot and
give it a good few taps with a hammer. I have yet to have not been able to remove using this method. Pouring some boiling water near the base of the
flange may also help unstick the rubber seal.
- Jim
steve m
posted on 3/5/12 at 08:00 AM |
I have always wacked a big screwdriver straight through the filter, and used that as leverage
also sometime trying to tighten it more will loosen it, sounds daft i know, but does work!
steve m
posted on 3/5/12 at 08:01 AM |
Its not a left hand thread is it ?
melly-g
posted on 3/5/12 at 09:46 AM |
Yep chisel and hammer for me too, usually works!
Ninehigh
posted on 3/5/12 at 05:28 PM |
We'll hear the "DOHHHHHH!" in the air if it is
posted on 3/5/12 at 06:05 PM |
I've never had a filter that I couldn't get off, had a few really tight ones . If you can get at the filter with a large pair of water
pump pliers (mine are about 18" long) then they will shift it . Failing that a chain type filter remover used with a decent length 1/2"
drive breaker bar normally works
steve m
posted on 3/5/12 at 06:29 PM |
I still maintain, your turning it the wrong way
Dopdog
posted on 3/5/12 at 07:11 PM |
come on then is it off yet?
posted on 3/5/12 at 08:23 PM |
if it is for the CVH - that is Ford engine so is standard RGH thread ... so unless OP is disoriented by being under the car, it won't be LH. ...
in fact, thinking about it, I cannot name a single car part other than steering components that will have LH thread, there should be no need to it on
an engine.
posted on 3/5/12 at 08:29 PM |
. in fact, thinking about it, I cannot name a single car part other than steering components that will have LH thread, there should be no need to it
on an engine.
Some wheel bolts and viscous fan couplings or a start
steve m
posted on 4/5/12 at 07:04 PM |
So is it off yet !!
flak monkey
posted on 4/5/12 at 07:08 PM |
You need these, never fails.
http://www.screwfix.com/p/oil-filter-pliers/38864?cm_mmc=Google-_-Datafeed-_-Automotive-_-Oil%20Filter%20Pliers&gclid=COPb2Y6q568CFQ1lfAodsndl1Q
maccmike
posted on 4/5/12 at 07:36 PM |
take sump off to have proper look.
computid
posted on 4/5/12 at 09:01 PM |
Right, got it off at long last. Hammered a huge spike through it and then stuck a rod on that and used a lot of ooomph to get it moving. Took a hell
of a lot but at long last its off.
Heres some photos for your enjoyment:
http://minari.atechplace.co.uk/wp-content/uploads/2012/05/2.jpg
http://minari.atechplace.co.uk/wp-content/uploads/2012/05/3.jpg
http://minari.atechplace.co.uk/wp-content/uploads/2012/05/4.jpg
Daddylonglegs
posted on 5/5/12 at 10:13 AM |
Well done! Bet that hasn't had an oil change in a while then??
