martinslyon
posted on 4/7/12 at 07:04 PM |
My Electric Three Wheeer Build
This illustrates the general arrangement of the main components
[img]
[/img]
martinslyon
| posted on 4/7/12 at 07:06 PM |
And this the packaging within locost type chassis
[img]
[/img]
[Edited on 4/7/12 by martinslyon]
martinslyon
| posted on 4/7/12 at 07:09 PM |
Aluminium panels and wheels attached
[img]
[/img]
martinslyon
| posted on 4/7/12 at 07:11 PM |
First assembly mock-up
[img]
[/img]
martinslyon
| posted on 4/7/12 at 07:13 PM |
Showing monoshock linkage
[img]
[/img]
martinslyon
| posted on 4/7/12 at 07:15 PM |
Simple and elegant front wheel drive upright
[img]http://
[/img]
martinslyon
| posted on 4/7/12 at 07:17 PM |
Front corner with drive shaft
[img]http://
[/img]
Will post more soon, would be interested to receive feedback and comments?
martinslyon
| posted on 4/7/12 at 07:24 PM |
Monoshock linkage detail
[img]http://
[/img]
martinslyon
| posted on 4/7/12 at 07:27 PM |
Labelled schematic
[img]http://
[/img]
martinslyon
| posted on 4/7/12 at 07:30 PM |
Bottom view
[img]http://
[/img]
Fred W B
| posted on 4/7/12 at 07:40 PM |
That all looks very impressive.
Pardon me if I've missed something, but what resists chassis roll in cornering with that setup?
Fred W B
martinslyon
| posted on 4/7/12 at 07:41 PM |
Fabricated swinging arm - similar to this.........
[img]http://
[/img]
martinslyon
| posted on 4/7/12 at 07:46 PM |
But I'm going to use this for now...........
[img]http://
[/img]
HowardB
| posted on 4/7/12 at 07:49 PM |
well impressive, what are you using for batteries?
Howard
martinslyon
| posted on 4/7/12 at 07:58 PM |
Fred W B
Nothing at the moment Fred, I'm going to build the prototype in this configuration to keep it simple and lightweight, the ultimate objective is
to develop a simple leaning mechanism that does not rely on hydraulics or electronics.
When I have it at a stage where we can test it we will evaluate how big a problem roll is on a wide based narrow three wheeler with all the weight low
down between the wheel centres, and if necessary convert to a sliding pivot with belville springs and washers or at the very worst a push rod twin
shock setup - but that would be an admission of complete failure and seriously dissapointing!
Thank you for taking an interest.
Regards Martin.
martinslyon
| posted on 4/7/12 at 08:02 PM |
Budget allowing - lithium-ion mounted on the floor where conveniant and low down on the outside of the main chassis in shaped aero pods.
Thank you for your interest.
Regards Martin
MikeCapon
| posted on 4/7/12 at 08:05 PM |
Wow. Nice work. Keep at it.
www.shock-factory.co.uk
martinslyon
| posted on 4/7/12 at 08:09 PM |
Cheers Mike - I will post an image of my monoshock - I would appreciate your opinion.
Regards
Martin
HowardB
| posted on 4/7/12 at 08:13 PM |
Regards Martin
What kind of range are you looking for? That is gong to be some kit when it is done,..
Howard
martinslyon
This is my Ohlins monoshock - allegedly from a Van Diemen single seater??
[img]http://
[/img]
martinslyon
| posted on 4/7/12 at 08:22 PM |
Regards Martin
Hi Howard, the starting point is to see what sort of performance we can get for a couple of hours, if it all turns out well I would like to see if we
can sustain a fun to drive performance car for a range of 120 miles with an 8 hour recharge cycle.
But it's all theoretical at the moment because EV's are a bit of a black art to me and so I shall be learning as I go and posting on here
to seek advice.
Thank you for your comments
Regards Martin
rallyingden
| posted on 4/7/12 at 08:56 PM |
Like the idea ........
What electronics are you using ?
What Voltage are you running at ?
DC or AC drive ?
Are you using regen braking ?
Keep[ up the good work
RD
watsonpj
| posted on 4/7/12 at 09:08 PM |
Hi Martin
I had a really good look at your pictures last week as its of real interest to me as I am also interested in an electric vehicle build. Mine is also a
single seat as I would like to use it as my daily driver to work (120miles round trip). I was looking at either a warp motor or a couple of agni
motors with lithium ion batteries. It started as a car with 4 wheels but i had come to conclusion that to lose weight a wheel needed to be
sacrificed. I'm no where near as far along as you appear but thanks for re invigorating my interest in the project.
Heres a picture of what I am think of,
[img]
  trike
[/img]
Please keep up the great work.
cheers Pete
| posted on 5/7/12 at 07:03 AM |
Have you calculated the magnitude of the stresses that will be seen in the front suspension? The extremely shallow angle of your pushrods means there
is going to be a very large compressive force on them and the bracket on the upright (and equally large tensile forces on the top wishbones). I
don't wish to be negative but gut feel says that something is going to bend.
martinslyon
| posted on 5/7/12 at 07:52 AM |
I'm afraid I haven't Mike, sadly my skills do not extend to that level of technical competence, having said that bear in mind that under
compression the pushrod will transfer force initially to the other side and then upwards via the front shock pivot, the pushrod angles and pivot point
design are still not finalised, everything in the drawings and photos is just a mock-up at this stage.
I'm on a mission and I'm going to build it in line with my vision, if I'm not happy with how it works I will modify and evolve
it.
I will keep your concerns in mind as I move forward and will report failures and successes so that other members can learn from my mistakes.
Thank you for taking an interest, Regards Martin
