<<  1    2    3  >>
Author: Subject: Breaking car, many brand new parts (duratec etc)
goaty
posted on 13/3/13 at 09:01 PM Reply With Quote
Right after it sitting all wrapped up for 3 years of not having any time i give up so all parts are for sale.
let the list begin;
All parts are brand new unless stated and either in box or mounted but nothing has ever been run.
Rotrex C30-94 kit with 110mm pulley: £1100
Custom GRS rad/intercooler inc fan (mounted) (same as flakmonkeys old one): £600
Escort 2.1 quick rack (covered 500 miles): SOLD
Escort steering column with quick release steering hub: SOLD
Seimens Deka injectors 630cc: £175
Cosworth roller barrel throttle bodies: £650 (prov sold)
Pulsar plenum and backplate to suit tb's: £60
Wilwood midilite Front vented brakes, all mounts, discs and pads and braided lines (covered 500miles): £350
OBP super light weight pedalbox, remote pots, complete bias and dash adjuster, hyd clutch, 3 MC's: £300
Customer ali header tank with low level swicth etc: £45
Type 9 quaife straight cut gearbox, just been serviced, new seals and bearings + short shifter 2.04 1st gear: £650
Type 9 duratec bell housing hyd clutch: £125
Slave cylinder to suit above and mount: £50
Tran x lsd diff for Atlas axle Grp4 gears (never out of box): £700
Tran x 2 peice grp 4 shafts 740mm(never fit): £300
Complete atlas axle 52inch, 3.75 open diff. Disc braked with cossy calipers, fit under 13's (mounts to suit coilovers/4 link etc): £350
Ali fuel tank, baffled, integral swirl pot, outlet, return and vent. suit 7 style kit: £125
Sytec 255lph external pump and seperate filter and mounting brackets: £75
Complete wiring loom to suit 7 style kit, full lighting etc including fuse boxes etc (installed but never used): SOLD
Omp D shape alcantara steering wheel (700 miles): £60
JK composites seats, black with black 5 pad set, carbon tops (500 miles, not one mark on them): £200 (prov sold)
Luke Gmax 4 point in black harnesses, Pair (500miles): £90 (prov sold)
Carbon fibre aeroscreen: £80
Carbon fibre cycle wings: £100
Carbon fibre rear arch stone gaurds: £50 (prov sold)
Custom carbon fibre silencer heat shield: £100
2 sets (8) 205/60/13 Yoko advan A048 tyres, 4mm on all: £200 a set (one set sold)
Spa plumb in fire system with two nozzels: SOLD
Forge competition dump valve: £30
4inch lights to suit 7 kit: £40 (prov sold)
Forged duratec 2.0
wossner 88.5mm 8.5:1
pec rods
acl race bearings
ARP main and head studs
ARP con road bolts
Key'd crank and pulley
Lightweight flywheel
Helix paddle clutch kit
All lightened and balanced, decked block. bored, honed and line honed. (all done and assembled by Scholar race engines)
Ported and polished head
Uprated piper valve springs and retainers
all new seals and relapped valves
All valves gaps set with new buckets
Cometic MLS headgasket
New chain and tensioners (cosworth items)
Denso spark plugs
Cleaned up front cover (de mounted)
Titan dry sump 3 stage pump
Ali water outlet
£3000 (prov sold)
Custom ali fuel rail to suit duratec: £75 (prov sold)
Racline tensioner: £70 (prov sold)
Lightweight denso alternator inc pulley: £50 (prov sold)
Magnacor ht leads duratec in blue: £50 (prov sold)
Digidash 2, inc loom and all sensors: £275
Also kit car breaking so ask for any bits too. Is complete car at present.
Think i have covered all but sure i will add bits i have forgotten (its been a while).
Again all parts a brand new and either bolted on or still in box unless stated.
Pics avliable on request and hope price are about right but open to offers, let me know if i offend...lol.
text or call, 07706 715297
[Edited on 13/3/13 by goaty]
[Edited on 14/3/13 by goaty]
eddie99
posted on 13/3/13 at 09:14 PM Reply With Quote
Bargains Galore... So tempted on pretty much everything!
Dibs on alternator
[Edited on 13/3/13 by eddie99]
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
goaty
posted on 13/3/13 at 09:16 PM Reply With Quote
i got no idea what its all worth, loosing fortunes here though....lol
RallyReason
posted on 13/3/13 at 09:35 PM Reply With Quote
U2U sent for seats,harness and h/lights
CRAIGR
Contributor
Posts 2760
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 13/3/13 at 09:48 PM Reply With Quote
u2u'd re rack
acafrao
posted on 13/3/13 at 09:52 PM Reply With Quote
2nd dibs for seats, harnesses and lights.
sdp312
posted on 13/3/13 at 09:59 PM Reply With Quote
rolling chassis
i am looking for a chassis and bodywork also front wishbones.
what ya got.
GavMax
posted on 13/3/13 at 10:07 PM Reply With Quote
Dry sump tank
Hi
Is the dry sump tank up for grabs please.
I need to replace mine. If it is, please could I have dims and a price please.
Many thanks
Gavin
marco
posted on 13/3/13 at 10:22 PM Reply With Quote
Dibs on this please, have you a closer picture?
goaty
posted on 13/3/13 at 10:35 PM Reply With Quote
what ya got.
It's a formula 27 with logbook
I am based near gatwick, what you wana know. Best phone me tomorrow mate
bi22le
posted on 13/3/13 at 10:38 PM Reply With Quote
that thing would be a weapon if ever completed.
i need some seats but cant be arsed on 3rd Dibs!!
good luck with the sale.
Please read my ring story:
Worzey
posted on 13/3/13 at 10:40 PM Reply With Quote
I'll have the Carbon fibre rear stone guards. Drop me a PM.
Caterham R400
goaty
posted on 13/3/13 at 10:41 PM Reply With Quote
It would mate but run out of enthusiasm, it all there just needs exhaust mani and ecu....
johnny chimpo
posted on 13/3/13 at 11:08 PM Reply With Quote
U2u'd..... But looks like i might have been beaten to it.....
henryc
posted on 14/3/13 at 07:09 AM Reply With Quote
steering column
Hello, I'm after a steering column with a bit more length, could you tell me how long it is from end to the boss face?
Would you be ok to post?
Thanks, Henry.
goaty
posted on 14/3/13 at 07:12 AM Reply With Quote
Thanks, Henry.
Please text me later to remind me and I will measure it post is no problem.
beardmore4072
posted on 14/3/13 at 09:51 AM Reply With Quote
U2u sent re: brakes and digidash. Thanks
clanger
posted on 14/3/13 at 10:37 AM Reply With Quote
u2u on various bits
franky
posted on 14/3/13 at 10:55 AM Reply With Quote
how much would you be after for the whole lot?
jeffw
posted on 14/3/13 at 12:09 PM Reply With Quote
pm regarding Axle.
ashg
posted on 14/3/13 at 01:45 PM Reply With Quote
jeff i work near gatwick so if you want me to pick up the axle i can save you a drive
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
ashg
posted on 14/3/13 at 01:48 PM Reply With Quote
dibs on the midilites
jeffw
posted on 14/3/13 at 02:25 PM Reply With Quote
Would be very kind
laptoprob
posted on 14/3/13 at 03:11 PM Reply With Quote
U2U re plenum.
Atlas
posted on 14/3/13 at 03:37 PM Reply With Quote
U2U Regarding seats. 4th Dibs if suitable and still available.
[Edited on 14/3/13 by Atlas]
<<  1    2    3  >>
