PeterV
posted on 11/12/13 at 11:12 PM |
Pit falls of a 1990 build
OK here is a question.
What are going to be the issues with Mr. IVA and a 1990's kit restoration and build?
No problem doing a complete rebuild of a classic, but something that has never been built but yet has kin that are on the road.... mmmmm......
For some fun I'm going to build / rebuild / start all over again a 1990's Carlton Carrera GT.
Seat position and seat belts is one that stands out.
Add radius problems almost everywhere.
But what else can you wonderful gurus of the build think of?
pmc_3
posted on 12/12/13 at 08:14 AM |
Has the kit already been on the road? If it's already got a legitimate v5 its just a case of an MOT at the end of the rebuild
Macbeast
posted on 12/12/13 at 09:39 AM |
What part of " but something that has never been built but .... " don't you understand ?
PeterV
posted on 12/12/13 at 09:47 AM |
No shes never been near a road. Has only ever seen back yards and front driveways
It's just about a rolling chassis with butchered bodywork. Actuall butchered everything but its getting better.
Chassis has been derusted repaired and painted.
Rear atlas axle is now sorted new bushes, shocks, springs and upgraded to disc brakes, 5 stud for 17" wheels.
Starting to sort out rear tailgate and rear bodywork.
Long long way to go
pmc_3
posted on 12/12/13 at 09:52 AM |
That will teach me to reply when I'm half asleep!
Macbeast
posted on 12/12/13 at 09:57 AM |
I would guess that, since you don't have a donor V5 you will probably have to meet the " as new " IVA regulations regarding eg
emissions etc. rather han the relaxed age-related specifications
iank
posted on 12/12/13 at 10:20 AM |
Not if it has a Ford engine with a number that can identify the manufacture date.
Anonymous
PeterV
posted on 12/12/13 at 10:28 AM |
No engine right now although there is a nice one on a pallet in my driveway. Smog test shouldn't be an issue as this pump is a SAAB 2.0 turbo
with CAT as per my WLR.
"IVA" Yep that's what I was thinking, just wondering if there was anything scary to worry about with such an old kit?
mcerd1
posted on 12/12/13 at 02:46 PM |
as long as its meets the requirements of the IVA manual it'll be fine
sharp edges and positions of things like lights and seatbelts could issues
so just print off the latest issue of the manual (free download from VOSA) you can check and adjust it as required as you build the car and
it'll be fine
I'd check the light positions first as there might not be much you can do to adjust them without affecting the look of the car...
mookaloid
posted on 12/12/13 at 03:14 PM |
As above /\/\/\/\ light positions - also you will need to do do wipers and heater/demisting etc as it is a hardtop.
PeterV
posted on 12/12/13 at 03:53 PM |
Cheers guys, hadn't thought of light positions. with a rough check I think I can get away with it but will have to fit rear fogs. None to be
seen on this model!
Heater and wipers ouch! Me had been thinking about that with some trembles and head pains I guess I need to study those regs over the coming
months!
Anything else? It's all sounding too good to be true
mcerd1
posted on 12/12/13 at 04:37 PM |
^^^ you'll also need a reversing light to go with that fog light
a lot of the rest will depend on where you source the bits....
the seat and seatbelt positioning could need a bit of fiddling to get right (for visibility, strenght and anchor points)
mirror sizes and visibility can be an issue (depends what you've got with the kit)
it needs 'protective steering' - a collapsible column from a suitable donor will tick that box though
you need a vin plate and vin number stamped in the chassis in the right places with the right size font etc...
things like heaters and wipers are easily sorted with generic setups if you've not got a donor one that will fit (classic mini's and
landrovers have wiper systems that are easy to adapt - basically the same as the lucas aftermarket ones you get from all the kit suppliers )
PeterV
posted on 12/12/13 at 04:55 PM |
Sierra column to replace this Cortina thing then.
VIN plate will have to be dreamt up as there is nothing at present.
Mirrors are a known, my WLR had a fail on these and needed a serious raising and bending to sort it.
Reversing lights are in the original cluster which is handy.
Seats and belts will have to sourced from someplace that has had IVA passes me thinks.
PeterV
posted on 12/12/13 at 05:04 PM |
As there is no anchor on one side of the sest coz this wss designed as a possible 2+2 or big hatch I guess I'll have to go for a three point
harnes?
[Edited on 12/12/13 by PeterV]
mcerd1
posted on 13/12/13 at 10:19 AM |
^^ 3 point will be fine as long as you fit them right
you can use the inertia reel ones out of a donor car as long as they are in good condition and you can mount them at the correct angles / locations so
that they work - basically just mount them the same way as the donor car they come out of
(if you were to fit them at a different angle/orientation they may not work - so best to find donor ones that suit they way you want to mount them)
mcerd1
posted on 13/12/13 at 10:30 AM |
is this the beast:
http://www.polarityservices.co.uk/carltonownersclub/useful/Sales%20Literature/Carlton%20Carrera%20Sales%20Flyer.jpg
not that bad looking for a 90's kit - sort of like the offspring of a capri and a GT6 :lol:
the right lights and a wee tweak/tidy up here and there and that could make a nice little car
PeterV
posted on 13/12/13 at 12:05 PM |
quote: Originally posted by mcerd1
is this the beast
Yep that’s the one and yeah I have plans to upgrade the original quite a bit without losing too much of the original looks. It's a bit of a
Heinz 57 between a Z280, 964, GT6 with some Esperante touches, all of which I quite like.
Should make a great support car for the WLR especially as it can tow
I’ve set up a build blog here if anyone’s interested
Carrera GT Build
As wifey will be driving it she's gone for this colour.....
.....me wanted black but hey ho out voted by wif & sprog. But a happy family helps with funding
mcerd1
posted on 13/12/13 at 04:42 PM |
that's not a mile away from the mk1 focus RS which is a very nice colour
PeterV
posted on 13/12/13 at 04:59 PM |
Tiz just a tad darker but very close to that. Can't complain to much with thier final choice (Bagpuss pink was getting very scray!!! )
sjmatthews
posted on 13/12/13 at 06:59 PM |
'E' marked windscreen?
I'll be in the garage dear!
PeterV
posted on 13/12/13 at 07:11 PM |
Doesn't all the glass have to be E marked?
James
posted on 13/12/13 at 08:02 PM |
Really like that!
- Muhammad Ali
PeterV
posted on 27/4/14 at 11:30 AM |
A quick update on the project and repost of the car pic (coz the website moved)
Most of the work so far has been restoration work on the old chassis and running gear. Suspension and steering refurbishment etc. Add in the upgrades
from 4 stud rear axel to 5 stud with the manufacture of wheel spacers. Then the conversion from drum backs to disc brakes at the back, which I had to
be custom manufactured as I wanted 5 stud. Both the refurbishment and upgrades to the project have all been great fun but have added loads of time to
the build.
4 to 5 stud conversion
Disc Brake Upgrade
All that work and only this to show for it
Slimy38
posted on 27/4/14 at 11:46 AM |
Make sure you check the IVA regs for towing capabilities, I vaguely remember a kit car magazine talking about the changes and how they make towbars on
kit cars virtually impossible to get approved.
PeterV
posted on 27/4/14 at 03:01 PM |
Shall not even attempt to get an IVA with towing setup. Will do that job once everything else is set up, legal and well sorted. As with the WLR, what
passed the IVA was a long way from what became a safe, reliable and comfortable car 18 months later. Can't see this one being any diffrent
