daveb666
| posted on 24/2/14 at 01:40 PM |
Live Atlas - LSD
I've been searching through haystacks for weeks now, and have finally found an TF LSD from a Capri.
The total cost including fitting is less than the cost of JUST a TranX/Quaife LSD (£850) but it is still a fairly significant amount of money.
When looking for one I had pretty much made my mind up that I wanted one... now that the opportunity has presented itself I'm teetering a bit
due to the numbers involved.
Will it really really be worth the money?
Ben_Copeland
| posted on 24/2/14 at 01:46 PM |
Whats the problem with your current setup?
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
johnemms
| posted on 24/2/14 at 01:48 PM |
A bit idle to go googling but..
Is there a kind of clutch involved in a LSD?
If so ..
Do you have to adjust or slacken a clutch or anything?
Coming from a heavy car to a light weight seven?
cheers
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
pewe
| posted on 24/2/14 at 01:51 PM |
If it helps I fitted a Torsen slippy diff to the other car (hairdressers c. 980kg and knocking out c.200).
Worth it for the grin factor alone.
In the dry fire it out of a tight corner, it locks up and goes like a rocket.
Can be a bit tricky in the wet if it locks un-expectedly but you do tend to anticipate that after a few brown trouser episodes.
Providing it's mechanically OK I'd say go for it.
Cheers, Pewe10
daveb666
I have an open-diff but on hard-cornering the inside wheel spins up. I also can't do donuts
If so ..
cheers
The LSD works in the same way regardless of the car; there is some setup involved when fitting into the axle but this is all taken care of by the
installer at the time.
Ben_Copeland
| posted on 24/2/14 at 01:59 PM |
Does not being able to do donuts warrant spending £850?
Ben
Roadster
daveb666
| posted on 24/2/14 at 02:01 PM |
I said it was less than £850
pekwah1
| posted on 24/2/14 at 02:07 PM |
you can do donuts no problem without an LSD, drifting however.... that's a different story!
I think drifting is worth the money
daveb666
| posted on 24/2/14 at 02:20 PM |
Really, how? It just spins the inside wheel - I noticed the same on the last trackday. There is no real control in the slide...
Ben_Copeland
| posted on 24/2/14 at 02:35 PM |
Would it be better to adjust the suspension so the front outside wasn't dropping so much as to cock the rear wheel?
Ben
Roadster
daveb666
| posted on 24/2/14 at 02:47 PM |
Dunno? Not too up on suspension adjustments tbh. I adjusted them when at Elvington to reduce under-steer - which worked but at Blyton last week I was
struggling to keep up with the 'diff'd cars' coming out of corners as I simply couldn't get the power down.
pekwah1
| posted on 24/2/14 at 04:35 PM |
No, when you're moving you wont get a donut, but if you do it from standstill it should quite happily spin round in circles!
| posted on 24/2/14 at 07:12 PM |
It works the same way, but if it's a plate type diff then the preload and ramp angles may not be suitable for a much lighter car e.g. what may
be a fairly tight diff on a heavy car could be like a solid axle on a lightweight one. OTOH if it's already well worn and quite loose, then it
won't have much LSD action at all. Well worth getting this right before the diff is installed.
yellowcab
| posted on 24/2/14 at 08:18 PM |
Not to tread on toes here, but Ben - Dave is looking for some excitement within his car…
He currently has an open diff, and having been passenger with him on the wettest track day I have ever encountered, where he was ultra committed, and
smooth and quick - I can imagine it being quite a boring drive, and not very 'thrilling', even mores in the dry.
As we're all like minded petrol heads, we strive for that adrenaline rush and speed - there is no point (imo of course) Dave spending more money
for more power, when he cannot use the power he currently has, as above - all that happens is that his inside wheel lights up - it requires no input
from the driver, you just keep your foot planted, no fun whatsoever (again, only imo)
Once he has an LSD fitted, he'll then have much more of an issue keeping it on the black stuff, as he won't be able to go 'all
balls out and if I break traction then it doesn't matter because only my inside wheel will spin which requires no driver input or
activity'
Getting an LSD will transform the car completely imo, once you can use the power you have, THEN you add more… but until then, more power will just
make your inside wheel even more bald, and quicker, and still remain no quicker around the track...
Ben_Copeland
| posted on 24/2/14 at 08:33 PM |
Was just trying to save him a bit of money. Sheesh. If his front suspension was stiffened a bit it might not spin the rear so much. Although in the
wet it probably won't help
activity'
Ben
Roadster
unijacko67
| posted on 24/2/14 at 09:18 PM |
You need an LSD for definite, what sort of power are you putting through it?
http://www.kittenkitcar.co.uk
daveb666
| posted on 25/2/14 at 07:29 AM |
I'm running a 2.0 zetec on TBs; 168bhp / 150lb ft torque and the car weighs 520kg without me in it
Neb
| posted on 25/2/14 at 08:56 AM |
The Capri LSD's are very rare, i would be inclined to make sure you can get bits for it.
We have a ZF in the Escort - it's the dogs back wheels, but was very expensive.
Is an ATB not an option? The 3J range is supposed to be decent too and made by the Trans-X crew before they were bought out by Quaife.
daveb666
| posted on 25/2/14 at 09:04 AM |
I know the Capri LSD is as rare as a virgin in Essex - the chap that has it is a gearbox installer/re-conditioner so the 'consumables'
needed to maintain/install it are available, that's not a problem.
The 3j/quaife stuff costs around £850 for the diff alone + fitting so comes in at well over a grand (which is crazy when the car only cost me twice
that!)
femster87
| posted on 25/2/14 at 09:21 AM |
Neb
| posted on 25/2/14 at 09:28 AM |
Try this for Gripper - Also have a very good name now and widely used in rallying.
http://cbradleymotorsport.co.uk/transmission-drivetrain/axle/atlas/atlas-gripper-lsd-large-18-spline-side-gears.html
The Capri unit sounds like a go'er. I would. You won't regret it.
Oddified
| posted on 25/2/14 at 09:43 AM |
The Capri lsd in the atlas axle is a ZF diff, and works very well. That what's in my car. Parts are available from Fostek or Burton Power
Ian
daveb666
| posted on 25/2/14 at 10:20 AM |
I think it's probably time I need to get my hand in my pocket LOL
yellowcab
| posted on 25/2/14 at 02:33 PM |
Never ever been said by a Yorkshireman, ever.
sdh2903
| posted on 25/2/14 at 02:49 PM |
