ChrissyDai
posted on 24/7/16 at 08:42 AM |
GTS Panther Body Parts!!
In my last post, I've been advised that the car I could be potentially buying, is in fact a Panther. I know this car is a rolling chassis, but I
am under no illusion that there are going to be parts and body parts missing! So! How hard is it going to be to source these parts please guys? (
I've read all,the previous posts) but wil other body parts fit such as bonnets actually fit?
big-vee-twin
posted on 24/7/16 at 09:13 AM |
The nose, bonnet, scuttle and rear tub are all higher than standard this was done to accommodate taller engines. Therefore the chassis design reflects
this too. I believe new owners took over GTS but can't remember who at the moment!
Found them DTR but don't seem to be around anymore.
[Edited on 24/7/16 by big-vee-twin]
http://www.triangleltd.com
ChrissyDai
posted on 27/7/16 at 06:53 AM |
Yeah you're right the link doesn't seem to work and I can't see much other info on the internet either. So does that mean that if
anybody damages their body parts on a Panther that's it now??
Slimy38
posted on 27/7/16 at 07:20 AM |
It wouldn't be the first kit car to not have replacement panels available. In fact, some production cars have extremely hard to obtain
panels!!
Fortunately it doesn't take much to repair an existing panel, or modify another manufacturers panel to suit.
craig_thomas
posted on 9/8/16 at 06:57 PM |
will a body from another kit not fit? what about the haynes roadster panels??
big_wasa
posted on 9/8/16 at 07:05 PM |
No the Haynes is a differant size.
No other make will match as the panther was unique in being an inch higher. The chassis is very much book from the rear bulkhead forwards .so panels
made to fit the book will fit the panther chassis but will be an inch shorter. With the exception of the rear tub as the rear bulkhead was an inch
taller.
[Edited on 9/8/16 by big_wasa]
craig_thomas
posted on 9/8/16 at 07:45 PM |
taller.
so would you be able to fit a locost scuttle/bonnet and nose cone (all being an inch shorter in height) to an already built panther?
big_wasa
posted on 9/8/16 at 07:46 PM |
Yes as a set of three.
craig_thomas
posted on 9/8/16 at 07:56 PM |
Do you know if the is any difference between locost body panels and Haynes roadster panels??
scotty g
posted on 10/8/16 at 03:55 PM |
The Haynes roadster i believe is 2" wider than the standard Locost.
rossgts
posted on 15/5/17 at 12:17 PM |
I know this is a old thread but did you have any success finding GTS parts?
I'm after some lower wishbones for my W7DE, I had seen them on the DTR site before that seems to be gone now
gavin174
posted on 11/8/17 at 11:09 AM |
I have some gts panther/wide bits laying around,
let me know what you need and I will have a look
