jambojeef
posted on 17/10/05 at 09:29 PM |
Aluminium Honeycomb
Hi all,
Where can I get some aluminium honeycomb from? I want enough to do a dashboard and cant find a supplier who will sell me thats small a
quantity...which is fair enough really - any ideas?
Sadly everyones favourite internet auction site has yet to yield anything even after a few weeks!
Geoff
donut
posted on 17/10/05 at 09:37 PM |
We recently took my eldest to a private school where they build and compete in electric single seaters. They construct their cars using floors from
helecopters!! Ally honeycomb sandwhiched between 2 sheets of ally.
Not very helpful but may point you in the right direction????
flak monkey
Why not just make it out of thin ali sheet suitably reinforced with a couple or ribs across the back?
Sera
http://www.motosera.com
jambojeef
posted on 17/10/05 at 09:41 PM |
Woah!
Me and me jigsaw are off to the airport!
Cool!
Erm I was going to go down the ally sheet road but Ive kinda done my scuttle a slightly strange way and need the depth and rigidity I think - might
get away with it - depends how easy it is to get at the helipad at Newcastle Airport.....now wheres my 500m 13A extension lead...
Triton
posted on 17/10/05 at 09:46 PM |
this might sound totally daft.....but two thin sheets of ali with foam sarnie will do the same trick especially for a dashboard......cheap as chips
then......
Mark
www.tritonraceseats.com
www.hairyhedgehog.com
jambojeef
posted on 17/10/05 at 09:51 PM |
DIY aluminium honeycomb!! WOW!
Like you mean the expanding foam stuff from B&Q?
this could be fun!
What could you use to like keep an even separation between the sheets as the foam expands?
For thick sections you could totally use that expanding green paper stuff they use to separate apples at the supermarket!
WOW!
Just gotta think of something to separate a thin dashboard type of thing...
Triton
posted on 17/10/05 at 09:53 PM |
See told you it was daft....thin insulation foam glued in between two sheets of ali.......but don't tell anyone or they will all want to do it
jambojeef
posted on 17/10/05 at 09:55 PM |
Im totally thikning this is the greatest invention ever - im thinking like thin strips of balsa wood criss crossed over a little sheet of ally and
then foamed and stick the other sheet over the top and weigh it down with loadsa books or sommat!
OH WOW! The helicopters are safe!
posted on 17/10/05 at 09:56 PM |
in the local craft shop i saw something called foam board, a wonrefully stiff car about 4mm thick with a sandwich of foam in the middle.
Any regular foam would do, not soap suds obviously, just a nice firm foam.
Triton
posted on 17/10/05 at 09:58 PM |
That stuff the flower bods use to plop flowers in would be ideal if you can find/steal/borrow some in thin sheets
jambojeef
posted on 17/10/05 at 10:04 PM |
What about this in the middle?
Loads for free at the back of the supermarket chekout!
![](/galpreviews/a270004-corrugated-cardboaord-roll.jpg) ![Rescued attachment corrugated-cardboaord-roll.jpg](/gallery/a270004-corrugated-cardboaord-roll.jpg) Rescued attachment corrugated-cardboaord-roll.jpg
viatron
posted on 17/10/05 at 10:06 PM |
Wouldnt the flower stuff break and crumble? How about a camping mat? only a couple of quid, the right shape for a complete piece for a dash and about
10mm thick?
Mac
Oh and its closed cell so is waterproof.
paulf
posted on 17/10/05 at 10:07 PM |
Try www.hmsales.co.uk, they are an aircraft dismantlers and sell anything from instruments to engines etc.The BBC and film studios buy bits of plane
from them for film sets etc.Someone i know bought a complete turboprop engine for about £300.Ive thought of trying them for ally honeycomb but never
got around to it yet.
Paul.
Triton
posted on 17/10/05 at 10:08 PM |
Just decided.....if you go this route your hair will turn green and hedgehogs aplenty will follow
robinbastd
posted on 17/10/05 at 10:09 PM |
Don't use Oasis flower foam as it absorbs water and doesn't want to let it go again. It's also bloody expensive to buy in sheets - I
had to make the base for a surf board shaped coffin top arrangement a few years back for the funeral of a local lad,and friend,who was killed in the
Bali bombing.
The blue foam from builders merchants would be better.
Ian
http://smuttygifts.com/
jambojeef
Do you mean I'll turn into grotbags off the pink windmill?
What an unexpected sideeffect of making your own aluminium skinned cardboard honeycomb!
Triton
posted on 17/10/05 at 10:13 PM |
You can actually buy slimline honeycomb stuff like that found inside those luvvly B&Q doors....used in carbon fibre work..weighs nowt but stiff as
a stiff thing
jambojeef
posted on 17/10/05 at 10:19 PM |
Im gonna try this tommorrow!
Might do 2 trials with foam and cardboard!
Should be good...!
Triton
posted on 17/10/05 at 10:24 PM |
Make sure you have a shower cap and some serious y-fronts on to catch those hedgehogs
Triton
posted on 17/10/05 at 10:27 PM |
Nasty little blighters yer know
robinbastd
posted on 17/10/05 at 10:35 PM |
Especially when fed with blue smarties.
Triton
posted on 17/10/05 at 10:44 PM |
JonBowden
posted on 18/10/05 at 08:36 AM |
Triton,
Thi guy here built a whole monocoque seven out of an aluminium and foam sandwich. He was
very proud of the stifness of the result
Jon
skodaman
posted on 23/10/05 at 11:46 PM |
Colin Chapman was known to use greaseproof paper sprayed silver but then again his F1 cars didn't need to go through SVA.![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif)
Triton
posted on 24/10/05 at 06:47 AM |
Colin Chapman was a demon he tried things people said won't work....and made them work........"God" thought he was C C but failed
big time
