RazMan
posted on 23/12/05 at 05:03 PM |
Rad hose joining?
I know I've seen these somewhere but the brain has gone into 'tilt' mode so perhaps someone can help me.
I need half a dozen alloy hose joining pieces for my 32mm radiator hoses. Ideally I also need one with a 15mm take off for the heater. CBS do a bolt
in jobbie but I don't really fancy drilling holes in a hose, and I'd rather get something which is made for the job.
Any pointers?
Raz
smart51
posted on 23/12/05 at 05:35 PM |
CBS will make aluminium tubes to your specification, including T pieces of different diameters. They will even roll the edges for you so that they
grip your hoses better. Their prices arn't too bad either. I bet they'll make just what you want.
mak
My motor factor "motorserve" does them , but thats in MK, i'm sure most motor factors will have them, took me a while to spot them,
best thing to do is phone and ask.
And i'm pretty sure those two sizes are supplied.
Good luck
PS: "Bolt in jobbie" sounds a bit suspect
posted on 23/12/05 at 05:39 PM |
Rally Design's new catalogue list's them, came free with Jan PPC. magazine.
RazMan
posted on 23/12/05 at 08:56 PM |
Actually since my first post I trawled around a bit and found some in various places but they all seem very expensive.
CBS will indeed make them up for me for about £8 a piece, Europa and Merlin are a bit more (but they are stainless). I can't find any mention of
them on Rally Design but I bet they are the most expensive.
Maybe its just me being Scrooge-like (well, it is the season isn't it) but I just feel that bits of short alloy tube should be cheaper
*edit* I take it all back! Rally Desighn do them for £4.58 ![](/images//smilies/shocked.gif)
Sorted
[Edited on 23-12-05 by RazMan]
Raz
posted on 23/12/05 at 10:17 PM |
32mm hose joiners from Rally Design £4.58 each +VAT , Sorry I was wrong about tee piece
iank
posted on 23/12/05 at 10:26 PM |
Merlin Motorsport sell these:
http://www.merlinmotorsport.com/advanced_search_result.php?keywords=hose+joiner
Not cheap unfortunately.
Chippy
posted on 23/12/05 at 10:55 PM |
Just buy a length of 32mm alloy pipe from your local metal dealer, and cut your own, much, much cheaper, keeps more beer tokens in your pocket.
RazMan
posted on 23/12/05 at 11:35 PM |
Ah but they will more than likely leak. The proper jobbies have ribs that seal better.
Raz
Mix
posted on 24/12/05 at 08:53 AM |
Have you had a look at what can be made from plumbing copper capillary fittings ?
Mick
RazMan
posted on 24/12/05 at 09:12 AM |
Unfortunately the plumbing suppliers only keep their standard sizes - 15mm & 25mm I think. These will do nicely for the heater though.
Raz
Fred W B
posted on 24/12/05 at 09:18 AM |
A tip that I saw on here - If using plain ally tube put 3 or 4 pop rivets through the ally tube where the bead would be. Should work just as well?
Fred WB
Mix
posted on 24/12/05 at 09:27 AM |
Standard sizes I have at the moment are 15mm, 22mm and 28mm ID or 17mm 25mm and 30.5mm OD#
Mick
RazMan
posted on 24/12/05 at 09:30 AM |
That's a top tip Fred - I might have to try that on my two main pipes already installed. I got the length slightly wrong and had to trim the
beaded ends off and I was worried about leaks.
Raz
RazMan
posted on 24/12/05 at 09:37 AM |
Mick
Close, but no cigar I'm afraid Mick - I've ordered 6 x 32mm from Rally Design
The only thing I need now is a 32mm to 15mm tee piece.
[Edited on 24-12-05 by RazMan]
Raz
posted on 24/12/05 at 10:53 AM |
Plain aluminium alloy or steel pipe is fine even ABS plastic works. No fancy ends needed just use decent quality hose clips.
--- dosen't leak at the joints
--- won't blow off
RazMan
posted on 24/12/05 at 11:05 AM |
I tend to go on the side of caution now days. I was having a hell of a time with my turbo hoses popping off the intercooler at 12psi until I got the
hose mountings beaded. After that - no problems even at 20psi.
I know that water systems don't run at those sort of pressures but I just like to use belt & braces I guess
Raz
NS Dev
posted on 24/12/05 at 11:06 AM |
Sorted
I would just buy 3 metres of 1.25" stainless steel hygienic tube, £20 ish for the whole piece.
Danozeman
posted on 24/12/05 at 11:53 AM |
As trident says. No beads needed. Just make sure both surfaces are clean and dry before u fit the hoses.
As for the t piece could u not get a standard one and get a 15 pipe welded on?
Dan
RazMan
posted on 24/12/05 at 12:04 PM |
quote: Originally posted by DanozemanAs for the t piece could u not get a standard one and get a 15 pipe welded on?
I probably could but I am pretty sure I've seen them for sale on one of the usual suppliers' websites. No sense in re-inventing the wheel
is there
I'm off to my local automotive store who stocks Gates hoses. I might find something ready made.
Raz
cornishrob
posted on 26/12/05 at 10:42 AM |
i was going to say that, why not buy a length of pipe? half the plumbing in one of my fiestas ended up as copper pipe.
RazMan
posted on 26/12/05 at 11:24 AM |
As I said earlier in the thread, plain pipe ends often leak or pop off under pressure so I want to have beaded ends to ensure that they are
reliable.
I looked thtough the Gates catalogue at my local store - hundreds of hoses in all sorts of configurations. I've ordered a couple of useful
looking ones to see if I can make them fit.
Raz
geoff shep
posted on 26/12/05 at 12:09 PM |
CBS do them but as you say, not cheap.
I got a reducing 'T' piece from an auto jumble stall at a show which I put into the bottom hose. It has longish narrow tube coming off
the T which is stoppered with an alloy bung - which I can use to empty the cooling system where I want and not have the coolant spray all over the
place.
Chris_G
posted on 26/12/05 at 01:07 PM |
Here's a top tip I picked up a while ago and used on my cooling system. Takes a little bit of time and patience but works a treat and is in the
'Locost' vain......
CLICK HERE
Chris
Now finished! Xflow-Zetec swap with GSXR TB's and Megasquirt.
RazMan
posted on 26/12/05 at 07:53 PM |
Excellent tip - thanks ![](/images//smilies/cool.gif)
Raz
