<<  1    2  >>
Author: Subject: Undoing Rear Wheel nuts...
Dangle_kt
posted on 2/1/08 at 11:27 AM Reply With Quote
I know this sounds dumb, BUT....
I took the wheels off my car, onto axle stands and then found a spacer on the rear hubs.
Problem is I can't undo them cos the flippin thing just spins with the axle.
There is no sticky out bits on the drum brake rear hub so shove a bar through a hold it steady that way, so I'm stumped. No engine so can't put it in gear, no hand brake so can't apply that...
any bright ideas guys?
How embaressing......
speedyxjs
posted on 2/1/08 at 11:31 AM Reply With Quote
Thats a tough one
speedyxjs
posted on 2/1/08 at 11:34 AM Reply With Quote
Just a thought, is there anything on the driveshaft you may be able to use like a uj you can stick something in to stop it moving?
Werner Van Loock
posted on 2/1/08 at 11:35 AM Reply With Quote
Bar between the studs?
http://www.clubstylus.be
russbost
posted on 2/1/08 at 11:36 AM Reply With Quote
If you have studs just jam a bar across 2 of them whilst you undo whatever secures these spacers, if you're on bolts just pop a couple back in & jam with a bar the same as with studs.HTH
Paul TigerB6
Nowhere to fit a couple of big bolts at all??
speedyxjs
posted on 2/1/08 at 11:37 AM Reply With Quote
i think that means he cant use the studs
posted on 2/1/08 at 11:40 AM Reply With Quote
try shouting and swearing at it like a madman - it won't undo them, but you'll feel better
As above, use a bar or steel strap wedged or bolted between the studs/bolts to lever against.
Dangle_kt
posted on 2/1/08 at 11:41 AM Reply With Quote
bar ACROSS the studs might work, they are done up pretty tight though, and if the bar slips.....
oh I never liked my knuckles anyway, so I'll give that a go!
cheers fellas! Couldnt see the woods for the trees there!
Howlor
posted on 2/1/08 at 11:48 AM Reply With Quote
Drop it down on the wheels is the best option.
Paul TigerB6
posted on 2/1/08 at 11:50 AM Reply With Quote
Pop a couple of nuts onto the end of the studs - will make sure the bracing bar cant easily slip of the ends of the studs. Worked for me with Sierra hub nuts and that took a 3/4 inch breaker bar with 3ft of scafold pole to move them and a solid steel bar to prevent the hubs turning
[Edited on 2/1/08 by Paul TigerB6]
Howlor
Reading it again though it looks as though you won't get at the nut through the wheel centre.
Sorry
Dangle_kt
posted on 2/1/08 at 11:59 AM Reply With Quote
I'll get my mate to hold it then!
HAHA!
Can't put the wheels on and drop it to the floor because of the spacer, I can undo the wheel nuts no prob, but the spacer nuts are between the wheel nuts so are covered by the metal of the wheels I'm using.
Tralfaz
posted on 2/1/08 at 12:37 PM Reply With Quote
Can you borrow/source an impact gun?
T
Marcus
posted on 2/1/08 at 01:03 PM Reply With Quote
At the risk of sounding silly, have someone stand on the brake pedal whilst you're undoing the nuts (apologies if you have no brakes)
Marcus
Because kits are for girls!!
Aico
posted on 2/1/08 at 01:15 PM Reply With Quote
Get an impactgun. Maybe you can borrow one or rent one? Or buy a (cheap) electric one 18V or so. Or put the nuts/bolts on there without the wheel. You can use that to hold the hub while someone else removes the spacer.
greggors84
posted on 2/1/08 at 01:26 PM Reply With Quote
Maybe a picture if possible would help as it seems no one really understands the problem.
Chris
The Magnificent 7!
Aico
posted on 2/1/08 at 02:19 PM Reply With Quote
It's a spacer which bolts onto the hub. The wheel is then bolted into the spacer.
2b_pablo
posted on 2/1/08 at 07:14 PM Reply With Quote
stick the ratchet/spanner onto one of the nuts and point the ratchet/spanner back across the centre of the hub. smack it hard with a hammer to break it loose.
gazza285
posted on 2/1/08 at 07:35 PM Reply With Quote
Spanner, yes. Ratchet, no. Unless you want to break it.
2b_pablo
posted on 2/1/08 at 08:48 PM Reply With Quote
depends what fits. wouldnt be the first time Ive thumped my rathet with a hammer lol! still going strong.
Dangle_kt
posted on 2/1/08 at 08:50 PM Reply With Quote
I dont have a sunken spanner set, and the bolts are recessed,
Pic is HERE:
[img]http://www.locostbuilders.co.uk/viewthread.php?action=attachment&tid=79671&pid=664292[/img]
blueshift
posted on 3/1/08 at 12:50 AM Reply With Quote
Put a bar across between the wheel nuts to stop the hub turning, then undo the spacer bolts with a socket and breaker bar / impact wrench.
Pretty much like everyone else has been saying really! Don't see the big problem!
Or, if you don't want to try and ebay the spacers - just grind the f**kers off.
[Edited on 3/1/08 by blueshift]
2b_pablo
posted on 3/1/08 at 09:29 AM Reply With Quote
from the pic you can easily put a bar through the wheel nuts
t.j.
posted on 3/1/08 at 11:27 AM Reply With Quote
Can't you just hold it and use a air-impact-tool?
<<  1    2  >>
