Paul TigerB6
posted on 11/1/08 at 07:57 PM |
GTS DeDion weight
Evening all
Does anyone know how heavy a DeDion unit is from GTS?? I am looking at saving some weight on my Tiger B6 build and as you will see from the attached
picture, the Tiger "designed" DeDion unit is rather "agricultural" in its.. ahem.... design!!!
The Tiger unit is built to accept standard driveshafts so which version would i need of the 3 shown on the website?? I am getting custom driveshafts
made up to suit the freelander diff so an exact fit isnt required but obviously want to keep the track right to suit the car. One of the GTS cars must
use the standard driveshafts???
[img][/img]
TimC
posted on 11/1/08 at 08:01 PM |
[Janice off of Friends]OH MY GOD[/Janice off of Friends]
flak monkey
posted on 11/1/08 at 08:02 PM |
Good god thats a fugly axle
The GTS panther de dion axle takes standard half shafts.
The axle weighs next to nothing. Probably about 10-15kg. You will probably need to move the panhard rod mounting on your chassis, but thats hardly a
big job.
Sera
http://www.motosera.com
Mr Whippy
weird
SALAD
posted on 11/1/08 at 08:03 PM |
I can weigh my axle tomorrow if needs be? Its a panther one.
Paul TigerB6
posted on 11/1/08 at 08:09 PM |
I havent weighed the Tiger item yet but it feels at least as heavy as a Sierra LSD diff so possibly in the 25 - 30kg region!! The flat plates you can
see around the apex and near the hubs are machined from 12mm steel plate!!! Not the greatest idea to go in a BEC.
Thanks for the super-quick answers guys (especially David).
I have linked here from the Tiger Owners Club site as there are a few people interested in converting their cars to DeDion from a Cortina live axle so
hello to all you guys - and while you are here get yourselves registered on this site!!!
Paul
Paul TigerB6
posted on 11/1/08 at 08:17 PM |
That would be fantastic if you could mate - thanks for that. Iguess there will only be small differences between the models due to the extra length of
cross-tube so maybe an extra kg for the wide version. I'll try and weigh the Tiger one (which is off their "lightweight" R6 / B6)
tomorrow as well.
SALAD
posted on 11/1/08 at 08:20 PM |
Mind your back when you lift it though won't you!
Benzine
posted on 11/1/08 at 08:23 PM |
quote: Originally posted by TimC
off of
lol
Paul TigerB6
posted on 11/1/08 at 08:24 PM |
Its ok - I have a 1 ton engine hoist in my garage!! It will be a good test to ensure it will take the Pinto / gearbox that I will be fitting for a
SuperCat build i am doing at the moment
stevec
posted on 11/1/08 at 08:29 PM |
I think GTS do a 2 piece De Dion, CalvinX had one
Steve.
Mr Whippy
posted on 11/1/08 at 08:49 PM |
what the one that snapped?
TimC
posted on 11/1/08 at 08:52 PM |
No.
Sometimes the punch-line is better left unsaid.
onzarob
posted on 11/1/08 at 08:58 PM |
Looking at a picture off Davids' site (Fantastic site David ), I would say you need to change the orientation of the shock mounting on the GTS
axel as well.
PS I think the scrap value of the old axel,may pay for the new one
locoR1
posted on 11/1/08 at 09:01 PM |
And to think i nearly brought a tiger cat before i built mine! good god that is one ugly axle
The standard sierra back end used in he cat looks lighter than that
Dave....
Check out my CB500T Cafe Racer build diary
Saucy Tenour
posted on 11/1/08 at 09:25 PM |
I just bought a panther when I went to collect my kit i asked about the broken axle and Darren said until recently it was a company called Aeon sports
cars who did all GTS's fabrication and that they had admitted liability for the faulty part.
He showed me they now do fabrication in house it looked good to me so they might be worth a call if you need a axle.
flak monkey
posted on 11/1/08 at 09:30 PM |
You are quite right. Aeon did make the faulty axle and its all be sorted out and won't happen again
This is probably a better pic of it fitted:
I believe the shock bracket is now better poistioned as well so it doesnt overhang the trailing arm brackets as much as it does on my axle. Not that I
have had any problems with mine yet.
Shock orientation is irrelevant as you can just turn the shock body around
Sera
onzarob
posted on 11/1/08 at 09:50 PM |
Won't it bind up unless its directly inline?
flak monkey
posted on 11/1/08 at 10:00 PM |
No, they will work just the same.
More importantly his rear shocks are on upside down!
Sera
COREdevelopments
posted on 11/1/08 at 10:31 PM |
well spotted david. i cant get over that back axle. who the bleep designed that!!!
stevec
posted on 11/1/08 at 10:42 PM |
Thats interesting David, According to one of this months Kit Car mags. Westfield fit their shocks upsidedown as standard to improve unsprung
weight.
What do people think of that theory?
Steve.
[Edited on 11/1/08 by stevec]
onzarob
posted on 11/1/08 at 11:41 PM |
Tell me I'm wrong, but if the shock mounts are not in-line, IE the bolts parallel to each other. and the shock is not at 90 degrees to the Axle
and top mount ,its going to bind up as there is a twisting action applied to it.
I think the mount will need to be rotated on the chassis by 90 degrees to mount the gts Axle properly.
PS mounting the shock upside down is OK to reduce unsprung weight, Just check manufacturer specs first
flak monkey
posted on 12/1/08 at 07:35 AM |
weight.
Steve.
It depends on what sort of shock they are. Oil filled dampers with adjusters have to be fitted in the correct orientation otherwise air gets trapped
in the asjuster. As far as I remember normal oil filled shocks with no adjuster also work best when mounted conventionally, again because of the way
the air bubbles in the oil move through the various valves inside the shock.
I know when we were looking at shocks for our formula student car we had to have single tube gas dampers so we could mount them on their side. Cheap
they were not! (Nitron shocks, about £180 each).
Sera
flak monkey
posted on 12/1/08 at 07:41 AM |
You arent wrong! My brain had evidently failed last night!
Sera
onzarob
posted on 12/1/08 at 09:37 AM |
Few!!! I was messing with a pencil and bit of paper trying to work out were my brain had gone wrong
