snapper
posted on 22/1/08 at 08:58 PM |
Welding
Just started my welding course at the local Ag college and with my first attempts at gas welding, i would have done better if i had used a Pritstick,,
lecturer said slow down a bit then i just blew holes in the plate.
More practise, more practise, more practise.
I eat to survive
I drink to forget
blakep82
posted on 22/1/08 at 09:03 PM |
rome wasn't built in a day, and they certainly didn't weld it!
________________________
tks
posted on 22/1/08 at 09:04 PM |
it also will depend on current settings!!!
if you go slower = more heat..
sow adjust the current settings.
anyway i would always start again and again reading the theory about welding..
you will discover that is not just sticking/melting...
if you learn the theory then you can cope with situations knowing how to react.../how to adjust..
Tks
Dangle_kt
posted on 22/1/08 at 09:07 PM |
I was meant to be starting one last week, but it was fully booked by the time I got round to put my name down.
Next one is April!!
At least they are still popular enough to run them ![](/images//smilies/smile.gif)
Mr Whippy
posted on 22/1/08 at 09:16 PM |
Really it's incredibly easy to do, understand a few settings on the machine and wiggle a little wire about...
I say don't wait till april, get some bits of scrap and practice. If it looks rubbish put some pictures on the site (not so big we need to
scroll) and we'll soon tell you where you’re going wrong.
[Edited on 22/1/08 by Mr Whippy]
Mr Whippy
posted on 22/1/08 at 09:19 PM |
Tks
I don't really agree as like painting you can read all the theory you like but only with practice will you actually learn to paint.
blakep82
posted on 22/1/08 at 09:24 PM |
people talking about current, wire, seetings on the machine...
gas welding, isn't it?
posted on 22/1/08 at 09:25 PM |
You cant adjust the current when gas welding although you can reduce the flame settings slightly. The original post mentioned GAS WELDING
Mr Whippy
posted on 22/1/08 at 09:34 PM |
too much heat from gas welding, end up with a bannana
Wadders
Don't be disheartened, IMHO gas welding is about the trickiest form of welding to master, not only does it require the coordination of both
hands, but your normally welding very thin metal which tends to distort and blow through easily. get your head round it, and MMA and MIG will be a
breeze. next hurdle will be TIG, both hands and a foot required
Al.
Dangle_kt
posted on 22/1/08 at 09:49 PM |
I'm ahead of you already mate. See the Arc wleding section on the MIG welding forum, one called "my first weld" by Dangle_kt....
that's me!
Got lots of advise, but no time to practice at the mo! Dam DIY!
NS Dev
posted on 22/1/08 at 10:54 PM |
Tks
current settings??? With GAS?
NS Dev
posted on 22/1/08 at 10:57 PM |
Al.
......though, as you will no doubt agree (I hope) I actually find it quite natural "driving" the tig with my right foot. I struggled far
more with gas (when I learnt it at school thanks to an enthusiast teacher who ignored the things we "should" have been learning at 13
years old!!) and have done since, whereas with tig I find it pretty easy apart from ally!
907
posted on 22/1/08 at 11:01 PM |
Mmmmm, Bronze Welded Chassis.
Nice
Paul G
quinnj3
posted on 22/1/08 at 11:53 PM |
Tig is proabably the best type of weld for welding a chasis cause it doesn't heat the steel as much therefore less pull. Problem is its a bugger
to do. I used to be able to do it very slowly, its been at least 4 months now since i've touched a tig welder so would need loads of practice
to catch on again. You need to be at it regularly to keep the standard up. suppose its the same with all types of welding.
my aim is to build my own locost wether it takes me a week or 10 years to get started, i'm sure i will sometime
quattromike
posted on 22/1/08 at 11:55 PM |
I have to do this for a job so I can say that the easyest by far is welding with flux cored wire on heavy plate, just point it in the general
direction you want to fill with weld pull the trigger and your away
I was trying to weld up a st.st. counter for our local take away today and it was a knightmare trying to get a nice small weld on thin sheet and
ended up makin little holes an puting bigger welds over them to cover it up
It is just practice, try a little ask someone change a setting here do it different there and after about 10 years you should be able to stick some
bit's together
OR! you could be on your way to designing a new teflon agent
"At the end of the day, I think it's going to get very dark"
bonzoronnie
posted on 23/1/08 at 10:12 AM |
Gas welding
Gas welding is a very good medim for the novice to learn.
It promotes hand & eye co-ordination as wel as giving you a good insight as to how the weld pool works.
The relatively low light output from a flame helps you to observe the welding process.
I am sure you tutor will give some great advice.
Apart from the basic gas pressure settings the main choices will be your nozle size. Probably a size 1-2 on sheet metal.
The type of flame you require for a particular task/material
3 types of basic flame can be used with a neutral flame being the most relevant to welding sheet metal
1: Neutral flame. Ox + Acet, equal
2: Oxidizing flame. Ox rich
3: Carborizing flame. Acet rich.
Gas welding is a little tricky at the beginning, but once mastered. You will have a solid platform when you move onto MIG, TIG and pehaps MMA.
Ronnie ![](/images//smilies/smile.gif)
dhutch
posted on 23/1/08 at 11:09 AM |
I learnt gas first, at the local collage, while i was at school.
- We did 10weeks, at an hour a week.
We started on about 4mm plate, just welding it at right angles in a jig. Then down to 2mm, then 1. Then progressed onto welding other shapes, diffrent
parts together, tube onto square section, etc.
It was a really good course, and ive been about to do feasably good gas welding ever since (i was about 14 at the time, now 20).
I then later largely self taught myself mig, and can also produce a functional weld with that too.
Just give it time. Its practice.
You can have diffrent nosel sizes with gas, but i presume they have you on the right one for the thickness of plate. What thickness are you
welding?
Daniel
posted on 23/1/08 at 11:11 AM |
I love gas welding, for some reason I find it tremendously satisfying and the results are so much neater than MIG. It's also far less fussy on
the surface finish of the metal.
Just don't pick up the welding rod by the wrong end...
rallyingden
posted on 23/1/08 at 12:15 PM |
I agree with MikeRJ
Gas is very satisfying once you know how to do it. You can control warping by the way you weld a job up, just keep swapping sides.
For practice just try doing a "run" along a sheet of metal trying to maintain a "pool" of molten metal. Once your OK with this
start "dipping" the welding rod into the pool as you go. Keep the rod in the flame but away from the blue hot spot until you want to dip
it, this preheats the rod and stops it sticking when you dry to dip a cold rod into the pool. You will get the knack in no time.
Plus once you have mastered gas welding Tig is a doddle.
Good Luck
RD ![](/images//smilies/smile.gif)
posted on 23/1/08 at 04:06 PM |
Bend a hook on the other end so you don't get it wrong I still have my Portapak and some gas, I welded the van with it last year. You can
warm stuff up and beat it into place to close gaps up etc.
gazza285
posted on 23/1/08 at 07:09 PM |
So many times............
posted on 23/1/08 at 07:41 PM |
Still got the scars after nearly 40 years
posted on 24/1/08 at 12:30 AM |
As I said
Bend a hook on the other end, it also stops nosy observers risking their eyes. I was taught this 30+ years ago and still do it now.
tks
posted on 24/1/08 at 11:32 AM |
Oeps...
Sow gas welding means Autogeen welding??
With the pure oxygen and pure red bottle stuff wich smelllss.....
I learned it at school to! (i am 24years old)
we welded a cubic thingy with gas and then we needed to pressure test it!!
mine never poored or blew up, they did shaped themselves like a ball (deform)...
the trick i applied by welding witht he flame is that if it gets to hot, you put te flame at more distance from the workpiece.. then it cools
down...
by managing that distance i managed the heat.
the flame is a basic setting (you need to see the small cones) you will need the correct nozzle number for the sheet thickness tough...
Tks
