<<  1    2  >>
Author: Subject: Twin turbo Jag V12 mid engined scratch built Zonda
James
posted on 4/3/09 at 11:18 AM Reply With Quote
Really nice. Keep us updated on your progress.
James
nicktruman
posted on 9/3/09 at 04:44 PM Reply With Quote
Today I started to glass fibre the body. I have never done this before so am making it up as I go along! The plaster was all rubbed down, I then covered the front with cling film. The I cut the matting to fit the various panels (with overlaps). The I laid the matting and poured resin over it, using a laminating roller I pushed the resin through. On the front alone I used 3.7 litres of resin! Once the first layer was done, I "tailored" a 2nd set of matting panels which I laid over the wet 1st coat. Again I rolled this with the laminating roller. It looks great, no wrinkles or rough spots (as far as I tell). I will let that dry and then cover in CSM surface tissue.
The idea is when all dried out I can lift the front off, get rid of all the polystyrene and plaster and then add extra matting from the inside.
I also cut the panels for the rear end which I will lay up tomorrow.
Regards
Nick
nicktruman
posted on 12/3/09 at 05:12 PM Reply With Quote
Yesterday I glassed the whole body with an extra laminate, today a friend came over and we took off the bonnet and cleaned out all th mold, awesome! The cling film worked a treat and has left me with a great finish (albeit on the inside). The steel frame had holes drilled in it and has bonded to the GRP, all in all its come out way better than anticipated.
On the rear panel we ground down all the high spots and filled the low spot and laid an extra layer of matting, I had made some molds based on the Hella modular lights these were pressed into the wet matting so as to create a snug hole for the rear light fittings. the result is I now have a really flat smooth rear panel with lights! I put a tin foil ring round the tail pipes just for the picture - but i am looking for a 10" (260mm) saucepan I can cut the bottom off to make this trim.
Tomorrow we are taking the rear off and will be removing the last of the polystyrene - this will give me access to the V12 for the 1st time in months.
Regards
Nick
nicktruman
posted on 17/3/09 at 08:27 PM Reply With Quote
herer are a couple of the latest pics
Regards
Nick
nicktruman
posted on 30/3/09 at 09:41 PM Reply With Quote
Now I have finished the passenger side sill and air intake.
I have made a steel frame and the side pod fits nicely. Just for fun i have fitted "carbon fibre effect" tread plates on the inner sill. When this photo was taken I had not yet fitted the sill to the chassis.
I can't remember if I posted it, but here is a video I shot last week of the car, one year on.
http://www.youtube.com/watch?v=-k_95tcZ0Oc
[Edited on 30/3/09 by nicktruman]
Regards
Nick
nicktruman
posted on 19/4/09 at 10:34 PM Reply With Quote
The latest..
I have fitted 2/3rds of the floor pan. I have the very front section under the suspension and the rear diffuser section still to do. I have also fitted the firewall between the cockpit and engine and most of the passenger side interior. Whilst I was making the inner sills I also fitted the two 300 watt speaker and hid all the wiring. It looks really smart now!
I have changed injectors to a lower throughput set 196 cc/min as opposed to 405 cc/min. This has put the fuel tables miles out, but it still runs, but the engine surges and hunts badly.
Regards
Nick
Fred W B
posted on 20/4/09 at 06:00 PM Reply With Quote
Hi Nic
You are making quick progress, but I have to ask - what are your plans for getting all those various edges straight and the shape symetrical when you bring up the final finish on the body?
As an example - looking at this pic, the top surfaces above the rear wheels , seem to be at different angles on the RHS and LHS? LHS looks about flat, but the RHS runs uphill from the outside towards the centre?
Fred W B
nicktruman
posted on 20/4/09 at 08:22 PM Reply With Quote
Originally posted by Fred W B
Hi Nic
Fred W B
Hi Fred, I hadn't noticed that one, More steel required!
Regards
Nick
Badger_McLetcher
posted on 23/4/09 at 10:58 AM Reply With Quote
Man this is a sweet project!
If disfunction is a function, then I must be some kind of genius.
cheapracer
Builder
Posts 156
Registered 29/11/08
Member Is Offline
Photo Archive Go!
Building: The Worlds next big thing of course!
posted on 23/4/09 at 01:30 PM Reply With Quote
Hi Nic
Fred W B
Mate the front looks a bit iffy to me as as well left to right.
Get some stiff cardboard and cut out some profile templates for every 6" or so so you can compare as you go.
I also use sheet metal profile templates to scrape bog/putty using the same one flipped for both sides.
It's coming....
nicktruman
posted on 4/8/09 at 05:19 PM Reply With Quote
Here is the latest on my kit car, mechanically its all there now, two more panels to make and then the body to finish off.
http://www.youtube.com/watch?v=AFzTsEO1XQE
however i'm off to Bahrain for 2 years so it will have to wait a while
nicktruman
posted on 1/3/11 at 12:14 PM Reply With Quote
So 18 months passed by, and I got bored and had the kit car shipped out to me here in Bahrain. It arrived on the 14th Feb 2011.
The plan is to make the most of the fibreglass factories and cheap labour and get a body professionally made. Tomorrow the country's weekly English speaking paper http://www.gulfweekly.com/home.asp is doing an article on the car, apparently its gets a lot of coverage! The only additions to the car since it left the UK are a new Lotus Elise windscreen, new fuel pump and I have just ordered a new water pump as the old Davies Craig unit is making a lot of noise.
Rather bizarrely the car was valued at $40,000 for import duty which was a bit of a shame, as I had to pay $2000 duty But i do get it back when I ship the car home.
Anyway, here is the latest pic of the car.
Regards
Nick
nicktruman
posted on 2/3/11 at 05:30 AM Reply With Quote
hi Guys
my car and I are on the front pages of the country's weekly english speaking paper
http://www.gulfweekly.com/article.asp?Sn=8139&Article=26597
in the printed version I am on the cover and page 2...
Hopefuly this will generate some interest in finishing off the body.
Regards
Nick
nicktruman
posted on 21/3/11 at 06:10 AM Reply With Quote
Here are the latest videos. as for performance, it accelerates from 14mph to 80mph in 5.9 secs at 70% throttle. This is calculated using the engine data from Megasquirt. The acceleration is awesome
I was getting 1 bar boost on each turbo, however since then I have had the headers reworked and flowed, and also stopped some air leaks on the intake.
http://www.youtube.com/watch?v=HDajtS34zmw
http://www.youtube.com/watch?v=R2-fkYuVm5Y
Regards
Nick
nicktruman
posted on 23/10/14 at 07:24 PM Reply With Quote
Hi Guys
I wonder if someone can help. I was wondering if anyone has had any luck megasquirt'ing an AUDI V8? (Hilly is using VEMS), I am after an ignition/spark advance map... any help would be really appreciated.
My car is just about finished, here are the latest pics..
Its been in the media recently quite a lot
Regards
Nick
<<  1    2  >>
