<<  1    2  >>
Author: Subject: Today's question - locking a bolt.
posted on 7/5/09 at 06:14 PM Reply With Quote
Caliper mounting bolts are normally 8mm with a coating of locking compound . Should be fine for your purpose David.
dave r
posted on 7/5/09 at 08:12 PM Reply With Quote
loctite 242 or 242a
the last one is the softest, and good for things like carb screws
dave
posted on 8/5/09 at 07:56 AM Reply With Quote
Originally posted by craig1410
Must say, I'd just use a spring washer - is there a reason why you don't trust them?
Nasty things, break into two pieces as often as not and chew up the fastener and part you are bolting down.
<<  1    2  >>
