hughpinder
posted on 1/9/09 at 02:10 PM |
Don't give up. There must be a decent auto electrical place somewhere near you.
Sadly we're on the other side of the country - there is a brilliant guy here in Grimsby.
Even if you end up throwing a couple of hundred quid to someone to sort it, its cheaper than the IVA.
Best of luck
Hugh
welderman
posted on 1/9/09 at 03:05 PM |
Thank's, Joe
I don't stalk people
Fozzie
posted on 1/9/09 at 06:34 PM |
Awwww Dangle..... sorry to hear that....
Don't give up.......you are soooo near to the finish!
Fozzie
Richard Quinn
posted on 1/9/09 at 06:48 PM |
It's got to be something daft like a short somewhere. If it's only just happened on the way there then look for signs of recent chafing on
the wiring. Systematically work from one end of the car to the other. If that doesn't reveal anything then it will be a case of disconnecting
the battery, replacing the fuse and checking each circuit for shorts with a multimeter. Failing that, it could be the reg/rec I suppose.
Wheels244
posted on 1/9/09 at 07:30 PM |
Don't give up Andy.
If you want to trailer it over to mine, we could give Gary from Autosparks a ring - the man is a genius with autoelectrics.
Rob
maximill666
posted on 1/9/09 at 09:20 PM |
Bad luck mate ![](/images//smilies/sad.gif) ![](/images//smilies/sad.gif)
Keep positive though, it will be worth it once its on the road
Dangle_kt
posted on 1/9/09 at 10:01 PM |
cheers for the words of encouragment folks.
wiring loom is goosed. Ho hum.
l0rd
posted on 1/9/09 at 10:26 PM |
Could you describe what it does?
Does it burn the fuse when you try to start the engine?
SOmeone might be able to quide you.
posted on 2/9/09 at 08:28 PM |
rotten luck - something must have chaffed the loom and shroted it big time.
should be possible to replace the bad part of the loom in a couple of weekends surelyu ... pity you are so far away ....
