<<  1    2  >>
Author: Subject: Zetec Type 9 Clutch Problem
dlatch
posted on 5/4/10 at 10:57 PM Reply With Quote
eddie wasa posted the part number in another thread just found it
ferodo CTK 1014
also it seems the early zetec clutch's which are the correct ones when using either a zetec 1.8 flywheel or the cvh flywheel, so it seems the holes on a cvh fly match the ones on a zetec.
good luck mate
eddie99
posted on 5/4/10 at 11:03 PM Reply With Quote
Thanks, Will give it a go tomorrow morning at a local motor factors!
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
eddie99
posted on 6/4/10 at 04:21 PM Reply With Quote
Got a mk1 mondeo 220mm Clutch today from a local motorfactors for £70. Bit expensive but i don't care because it seems to have worked.
Not put engine back in the car yet, just finishing of a few jobs while theres more space in the engine bay for the mo but hope to get it back in the car over the next few days...
Thanks everyone for all your help!
Ed
westy7
posted on 9/4/10 at 09:54 PM Reply With Quote
Eddie
Just be mindfull if your using a 1.8 mondeo clutch
your power is no more than 160 bhp
as thats about the limit for these clutches
eddie99
posted on 9/4/10 at 09:56 PM Reply With Quote
Thanks for the headsup but standard the engine should be about 130hp max so will have a way to go. Plan on tuning it a bit in the future but to get it on the road first!
posted on 10/4/10 at 08:40 AM Reply With Quote
Originally posted by westy7
Eddie
Thats the limit in a tintop weighing lots.. not really relevant in a lightweight weekend car...
I'll let you know how many miles my 1.8 clutch lasts behind the ST engine.. 3500 miles so far.
eddie99
posted on 10/4/10 at 01:36 PM Reply With Quote
WOOOHOOOO.
Engines back in and clutch works. Unfortunately going out for rest of day tomorrow but list of things todo tomorrow before the first drive:
Fill Diff and gearbox with Oil
Tighten up proshaft
Tighten up Engine Mounts
Tighten up rear suspension
Fill the cooling system.
Put the engine wiring back in!
Then the day i've been dreaming of for so long might happen?
WooHOO
dlatch
posted on 10/4/10 at 03:44 PM Reply With Quote
yay!!!
nice result eddie, remember first drive vid posted or it never happened and we won't believe you
[Edited on 10/4/10 by dlatch]
westy7
posted on 12/4/10 at 08:56 AM Reply With Quote
Just to let you know i have the same ST170 engine fitted in my westy
and a brand new 1.8 mondeo clutch and flywheel were fitted
at Emerald last week the clutch burnt out because it couldn't handle the extra power and torque of the ST
I had the same set up on a silvertop pushing 160bhp and never had a problem
just saying if you have more than 170ish bhp you may need to urpate the setup as your pushing the limits of the clutch
[Edited on 12/4/10 by westy7]
<<  1    2  >>
