<<  1    2  >>
Author: Subject: BEC reverse set up ??
neo2
posted on 13/7/10 at 07:29 PM Reply With Quote
I got mine for £156 3 weeks back as they matched the pre price increase price..
Davegtst
posted on 31/7/10 at 09:42 PM Reply With Quote
Got my sprocked painted and fitted and i'm in the process of modifiying and mounting the starter. MK have changed the width of the tunnel, mine is 110mm inside of the tunnel chasis rails compared to the 99mm of yours. Because of this your brackets may need altering but it does leave plenty of room around the sprocket and tunnel sides.
Davegtst
posted on 1/8/10 at 02:10 PM Reply With Quote
Mine is all fitted and working Made up a little bracket to fit and even a cover for underneath. Works very well although it is a bit noisey.
neo2
posted on 2/8/10 at 05:58 PM Reply With Quote
Some good pictures there mine is very very similar but still have the floor cover to make to cover the solenoid sticking out the floor..
brookie
posted on 2/8/10 at 07:13 PM Reply With Quote
so if u do this your self how much do they cost for all the parts
Davegtst
posted on 2/8/10 at 07:24 PM Reply With Quote
It's cost me £214 for the sprocket and new starter motor. You can get cheaper used starters which are probably fine but virtually everything else on mine is new so i paid the extra. At £214 it's still £136 cheaper than MK.
neo2
posted on 4/8/10 at 07:22 PM Reply With Quote
Mine cost the same £214 for starter and sprocket but spent another £50 ish on cable switches and relay and fuse and holder etc..
brookie
posted on 5/8/10 at 03:40 PM Reply With Quote
thank u
s6otty
posted on 27/12/10 at 02:28 PM Reply With Quote
Dave,
Do you have the Part No. of the starter you used in the end, I've found loads and don't know which one to go for!
Scott
40inches
posted on 27/12/10 at 05:04 PM Reply With Quote
Originally posted by s6otty
Dave,
Scott
Check my post, about 11th down, all those models use the same starter
tompat3463
posted on 4/4/11 at 07:39 PM Reply With Quote
my fiend work as an cnc machinist if anyone would like a gear made for reversing systems. he made mine and its fitted.
Im just wondering how to wire the reverse up.. considering I have my switch located do i simply run wires to the starter soleniod or do I need a relay ???
I.e. if u simply connect + and - to soleniod will this then push the gear into working position and turn the motor ??
TIA Alan
40inches
posted on 5/4/11 at 01:35 PM Reply With Quote
TIA Alan
Live from battery to large terminal on solenoid.
Another (smaller wire) from live on battery to spade connector on solenoid via switch, I would either use a 25amp rated switch, or fit a relay You need a fuse on this wire.
The earth will return from the starter mounting points
phoenix70
posted on 5/4/11 at 02:28 PM Reply With Quote
TIA Alan
So how much would the fiend , err, friend charge to make the gear up.
Scott
Johneturbo
posted on 5/4/11 at 02:52 PM Reply With Quote
What's wrong with just getting out and pushing
adithorp
posted on 5/4/11 at 03:06 PM Reply With Quote
Nothing if you've already got registration... but the IVA man won't accept that as a reverse.
http://jpsc.org.uk/forum/
Johneturbo
posted on 5/4/11 at 04:16 PM Reply With Quote
Yep i know that, is that the reason the original poster wanted a reverse
[Edited on 5/4/11 by Johneturbo]
main82000
posted on 11/3/12 at 12:21 PM Reply With Quote
just got mine in the post from hpc gears with the use of 40inchs paperwork and that came to
reverse gear £165 del
starter motor £56.70 del from eurocar parts
<<  1    2  >>
