cd.thomson
posted on 19/7/10 at 11:17 AM |
there may also be the slight issue that i played my "joker" on the phone and told him vauxhall couldn't find any details of the
engine so haynes was the only thing I had. So I'm not sure what his reaction will be if I turn up with a letter?!
He just said there was nothing he could do at his end so no point me retesting it until I could provide something relevant.
If I do pass the test is there anyway he can stop me registering the car once he gives me a mac?
[Edited on 19/7/10 by cd.thomson]
Craig
speedyxjs
posted on 19/7/10 at 11:25 AM |
Just an idea, How about going to your local main stealer and seeing if they might be able to find out from your specific engine number. they may have
'contacts' in Vauxhall how may be more helpful?
omega 24 v6
posted on 19/7/10 at 11:28 AM |
Highly unlikely but bear in mind that if you fit a cat etc etc and he passes it it will most likely be at the stricter cat emissions
so if you remove the cat then you will need to probably refitt it come mot times![](/images//smilies/sad.gif)
oh and you have U2U
tony-devon
posted on 19/7/10 at 11:41 AM |
even if you proove that the engine was from before compulsory CAT's is it possible that he will say it has to have one anyway as the engine
originally was fitted with a cat, hence the C in C20XE
just a thought but can you lay your hands on an old 2l 8v lump a 20ne or 20seh?
fit that get it tested and then swap engine back?
I now always keep a photocopy of the logbook that the donor engines come from
although as mine are all bike based, my MSVA test is far easier, but next project after this is a car, so already thinking ahead
heavy is good, heavy is reliable, and if it breaks, hit them with it
omega 24 v6
posted on 19/7/10 at 11:45 AM |
There is the problem because not all c20xe's had a cat fitted. my one did not but was still a c20xe stamped block ( original engine) luckily I
also had a 20xe which i fitted.
cd.thomson
posted on 19/7/10 at 11:48 AM |
Cheers tony, but thats not the case.
He's happy to test me as per the emissions test flowcharts which only take engine age in to account, not whether it was fitted with a cat
originally.
Craig
Mal
posted on 19/7/10 at 11:51 AM |
Contact a Vauxhall engine tuning company such as SBD to see if they can offer any help.
Also, try a Vauxhall dealer to see if their computer system can find the car registration number, and hence date from the engine number.
pewe
posted on 19/7/10 at 12:00 PM |
Craig, tugging at my long grey beard (well it's not that long) - you've spent a considerable amount of time and money reaching here.
Whilst the odds may currently seem stacked against you we all recognise the frustration of taking one step forward and two back when it comes to the
build and putting it on the road.
I reckon to a man (and ladies) we'd all say that the end result makes the frustration worthwhile - see the number of responses you've had
in such a short space of time.
Do not give up - hang in there - you WILL resolve your problems - it WILL be worth it.
HTH.
Cheers, Pewe
[Edited on 19/7/10 by pewe]
James
posted on 19/7/10 at 12:40 PM |
Vauxhall website and get a logo.
You got Word right? Got a printer?
Is there still a problem?
If you want extra evidence put a phone number of a mate who's primed with the full story. Or even leave your landline number and leave a
"You've come through to X Vauxhall dealership" answer phone message.
Job is job!
cheers,
James
[Edited on 19/7/10 by James]
- Muhammad Ali
l0rd
posted on 19/7/10 at 12:50 PM |
where is the number stamped?
According to this website
http://topbuzz.co.uk/info/engine_codes/engine_codes.htm
The engine code shall be stamped below the cylinder head (up to 1993), usually on a small flat surface. But after 1993 the location moved to the edge
of the cylinder block, transmission side.
posted on 19/7/10 at 12:56 PM |
I reckon to a man we'd all say that the end result makes the frustration worthwhile - see the number of responses you've had in such a
on a scale of to 10, where death is 10, it doesn't really rank that highly.
bottom line is it is gonna cost you money - either for a CAT, another dated engine or some other means and maybe IVA test fee but none of that is
the end of the world
admittedly when you are broke, even a hundred squid is a big deal.
hang on in there list up you options and then find the one that is easier/cheapest.
posted on 19/7/10 at 01:03 PM |
I'd stick to an officially sourced document Craig... this tester sounds like a right one and could end up turning detective to drop you in the
doo-doo!
It's Evolution Baby!
dhutch
posted on 19/7/10 at 01:15 PM |
You can get a purchase receipt for the engine easy.
- It very least, you can sell it to your mate for £0.50 and then buy it back an hour later for the same! Engine doesnt even have to leave the
car.
Daniel
cd.thomson
posted on 19/7/10 at 01:19 PM |
doo-doo!
A user on here has informed me that their letter from vauxhall just confirmed their engine was made before the end of 1995 - which is basically the
information I have already.
I see no way round this at all considering my £200ish budget (thanks dad) and 4 weeks until I move away.
Craig
Liam
posted on 19/7/10 at 02:01 PM |
I'd be considering going above this numpty's head and writing a letter to VOSA strongly complaining about this guy's attitude (using
his name), pointing out that you can prove the engine wasn't even produced after 1995, that even from Vauxhall themelves the specific date of
manufacture of the individual engine is not available, not that that should matter given the above, that other vehicles with the same engine have been
sucessfully tested, that you have paid a significant sum of money for the test and are deeply unsatisfied with the service you have received from
VOSA, etc etc etc.
Maybe worth a try? Good luck and dont give up. Why is it so critical it's done and dusted before you move away? Never planning to come back? ![](/images//smilies/smile.gif)
scudderfish
posted on 19/7/10 at 02:25 PM |
Wot Liam said ^^
http://www.dft.gov.uk/vosa/contactus/complaintsprocedure/complaintsprocedure.htm
iank
posted on 19/7/10 at 02:56 PM |
Since you told VOSA that Vauxhall don't know when the engine was manufactured it would seem to leave you in the position of changing the engine
or fitting a cat. A letter from Vauxhall will be treated as proof because they are talking about your engine, haynes just talks generally about
models not about when your specific engine came down the line so wouldn't ever be taken as proof - you'll need something better than that
as an appeal (the 'lots of other people passed SVA' gambit is also unlikely to do the job at least without names, dates and test
stations). Ford encode the year of manufacture in the engine number so are MUCH easier to prove with less paperwork required.
Forging Vauxhall letterhead might have been an option but as VOSA are rumoured to monitor this site amongst others it doesn't seem wise now even
if the guy didn't know you were desperate.
BTW you won't get a MAC until you pass the test, and you won't pass the test until it passes emissions one way or another. So I'm
not sure what you mean about passing the test and them stopping you registering.
Which brings me to a final point. Abusing a VOSA official for doing his job according to the rules given to him on a public forum that may be
monitored using your real name doesn't seem likely to lead to an easier path to getting the car on the road. So despite your frustration
staying reasonable and polite is the only sensible option.
Anonymous
Liam
posted on 19/7/10 at 02:58 PM |
I might let the guy know first that I'm going to complain about him personally - see if he squirms a bit and backs down to save you the bother.
James
posted on 19/7/10 at 03:15 PM |
Could you book your retest at a different station? Get a more reasonable inspector?
- Muhammad Ali
russbost
posted on 19/7/10 at 03:19 PM |
This guy is obviously going to stick to the letter of the law so don't provide falsified proof - will probs only make matters worse.
Talk (calmly & sensibly) to Mark Vickers, Steve Bardsley, or Steve Jones at VOSA, 01792 454256, 01792 454351, they will give you the official
requirement of what you need to do to prove the engine age & their view may be different from the testers. I have found these guys most helpful,
they can't tell the tester what to do, but if they advise one thing, he does another & you take the matter to appeal you have a very strong
case.
Best of luck & don't flush it all down the tubes over something so minor - if worst comes to worst bung an older engine in that you have
proof of age for & swap it out afterward
Surrey Dave
posted on 19/7/10 at 03:29 PM |
Softlad??
None of us like to be 'pulled up' when we've made a bit of tit of ourselves .
Obviously the reference to me being 'Softlad' (Someone with a weak personality. A wimp, a pussy, a soft person) in your reply was an
insult in retribution.
Can say no more..................
Is there anyone on here who could lend you a cat system for your engine?
l0rd
posted on 19/7/10 at 03:58 PM |
Can't you speak to VOSA and ask them for the information on what car the engine was installed in?
They must know.
![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
l0rd
posted on 19/7/10 at 04:11 PM |
Something a bit dodgy
There is car on Ebay, A 1995 Calibra
http://cgi.ebay.co.uk/1995-VAUXHALL-CALIBRA-GREY-/150469260639?cmd=ViewItem&pt=Automobiles_UK&hash=item2308aab55f
Can't you ask him the engine number if it is a Red top and then offer him some money and explain the situation if he can photocopy the
information that you require from the logbook?
Dodgy but you will never know if you don't ask.
if your engine number is lower in the food chain than his car then there you go. His 1st registration was in Aug1995. Just on the cut out date.
[Edited on 19/7/10 by l0rd]
Liam
posted on 19/7/10 at 04:46 PM |
doo-doo!
Iank makes an important point though - there is a crucial difference between the haynes info you have and the vaux letter. Presumably the vaux letter
says something along the lines of 'the engine enquired about was made before end of 1995' - i.e. it relates to a specific engine, so is
not just 'basically the information you have already'. Have you actually asked the guy if he would accept such a letter (maybe show him a
copy of it for an example)? He might which would leave you only with the lesser problem of getting a reciept (have you tried where/who you actually
got it from?) and raising the £100 to get the letter. If he's really not going to accept the vaux letter then you have grounds for a proper
complaint.
big_wasa
posted on 19/7/10 at 04:50 PM |
If all he wants is a cat then get one.
link
I am sure some one on here would weld it on for you.
Thats got to be the best sollution ?
