<<  1    2    3  >>
Author: Subject: self-centering
cd.thomson
posted on 9/8/10 at 08:25 PM Reply With Quote
Originally posted by locobri
One of our club members has just gone through the IVA with his GKD Legend, He'd fitted a set of springs inside the steering rack and this worked a treat and passed that part of the test.
He's getting me a set of them to just to make sure I' get that bit right as well.
I'll post some pic's as and when I fit them
yeah that'd be great locobri, be interested to see how they work
Craig
nitram38
posted on 9/8/10 at 10:02 PM Reply With Quote
Right do a search and yes, I do bang on about this.
Castor isn't just for fun!
When you drive into a corner, the feedback from the steering should be of that the wheel is trying to straighten again in your hands.
It is vital you get this right otherwise you are driving a dangerous car.
I've corrected my suspension by changing the top wishbone so that it is slightly further back than the bottom bone giving both my builds 7.5 degrees and changing the car from vague to ones that feel good out of corners.
The alternative is having to feed the steering back to straight ahead which is not only un-natural to most peoples driving but means you can't feel the road.
Springs, toe in, toe out, tyre pressure changes all work at low speeds, but when you are recovering your car from a ditch, don't say someone hasn't warned you.
Oh and trusting manufacturers to do this stuff? Some are still producing wishbones with no castor
[Edited on 9/8/2010 by nitram38]
matt_claydon
posted on 10/8/10 at 06:32 AM Reply With Quote
Amen. I don't understand why people are so happy to bodge
PeteS2k
posted on 10/8/10 at 08:09 AM Reply With Quote
Nothing wrong with the Rush steering geometry from a self-centring perspective. There's plenty of castor designed in (9.5 deg measured on mine).
It's the initial stiffness (excessive pre-load) in some installed lower ball-joints that seems to cause the problems.
cd.thomson
posted on 10/8/10 at 08:13 AM Reply With Quote
I'm not in the slightest bit "happy" about bodging.
Craig
PeteS2k
posted on 10/8/10 at 08:36 AM Reply With Quote
U have U2U
matt_claydon
posted on 10/8/10 at 05:45 PM Reply With Quote
Sorry, wasn't referring to you, but to all the people who seem to advocate time and again putting valve-springs etc in the rack. I just don't understand why after nearly 10 years, the cars are still being sold with incorrect (and to be frank, slightly dangerous) suspension
It sounds like the Dax (unlike MK et al) actually has the correct geometry anyway, in which case your problem is most likely down to a stiff rack, column, or ball joints.
Madinventions
posted on 10/8/10 at 10:23 PM Reply With Quote
Just because some people fit springs etc to aid the self centering test during IVA, doesn't automatically mean their geometry is wrong. The springs etc are a sure-fire method to overcome initial stiffness in the system and only come into play at full lock. Previous posts are completely correct - during normal driving, it's the geometry that gives you the correct feel and safety factors. But, for the 'show a degree of self centering from full lock' test during IVA you sometimes need some mechanical help to overcome the tightness of new steering components.
Of course, it's imperative that every new build has a decent amount of time spent on it to get the geometry set correctly - it makes a huge difference to handling and safety. Get this right first and then think about springs etc if you still need them, (and your test/retest date is looming...)
Just my 2p's worth...
View my band website:
http://www.shadowlight.org.uk
nitram38
posted on 11/8/10 at 05:15 AM Reply With Quote
If you get enough castor then you shouldn't experience these stiffness issues. Often these cars have too little castor for road use coupled with new componants. Racing cars are slightly different in that they often use a bit less.
Madinventions
posted on 11/8/10 at 10:32 AM Reply With Quote
But if you have too much caster then the steering can get too heavy and you can start to loose the 'feel' that we all want from our cars. Also, the steering can tend to kick if you go over a bump, and changes to camber during cornering will also increase. As with anything, it's a compromise and once you're past the 'safety' aspects (ie. making sure it doesn't try to spit you off the road), a lot of it is down to personal preference - especially the differences between setting up for track days, or just for road use.
My cars is mid engined and I run about 5-6 degrees of caster and the steering is nice and light while still being positive and straight line stability is good. I've got rubber tubing on the steering rack ends but this only ever comes into play at full lock so has no effect whatsoever during normal driving. It just helps when parking etc.
Happy days
Ed.
cd.thomson
posted on 11/8/10 at 10:38 AM Reply With Quote
Am I right in thinking correct "castor" would manifest itself with the upright sitting on a diagonal axis with the top of the upright closer to the rear than the bottom of the upright?
Just checking my wishbones are right
[Edited on 11/8/10 by cd.thomson]
Craig
Madinventions
posted on 11/8/10 at 10:53 AM Reply With Quote
The top should be further back than the bottom, like this.
Ed.
cd.thomson
posted on 11/8/10 at 10:59 AM Reply With Quote
cheers ed! Simple enough.
Looks to be plenty on my car, so I doubt thats an issue!
Can anyone explain what effect caster actually has? Basic physics/engineering welcome. No point building a car if I don't learn something at the same time!
Craig
procomp
posted on 11/8/10 at 11:01 AM Reply With Quote
Hi
I really can not believe that this subject is still coming up for discussion and argument . The fitment of valve springs in to the rack to aide self centering is not accepted by the IVA. If they find out they are fitted they will fail you.
Now if you have 5 deg of castor and geometry that is in the ballpark of being what the car would require to be driven normally it will pass the IVA without problem there should be no need to start setting the geometry up with way out settings just to induce self centering. What most are missing is that castor dose not just give you self centering that is only a small effect of what effect it has on the geometry whilst turning.
Now the problem here is that just about every one of the main kit manufacturers have such poor control of the jigging on there chassis that if you actually measure the castor properly you will find that they fall well short of what the manufacturers actually claim. Most only have 2-3 deg rather than the 5 deg than they claim. Then there's the problem that the jigging from left to right is also poor so you get differences of up to 4 deg across the car.
The claim that ball joints are too stiff is also a bit dubious. If a joint is stiff enough to stop a car with a genuine 5 deg of castor self centering then the joint is not usable and should be discarded because manipulating it to loosen up is only going to give it a short life span or worse case scenario damage the construction of the casing where it has been pressed over leading to it becoming possible to pull the inner ball out of the casing.
If you do not have the required castor for your car or application as there's a difference between a CEC and a BEC you are not just lacking the ability to have self centering ability you are lacking some of the basic geometry to control camber during cornering and with out it you will never have a car that will handel as it should giving positive feedback and feel. Illegally bodging it through the IVA test and ignoring the fact it is not right is also robbing you of having a car that is much more pleasurable to drive and more importantly helping you avoid situations that could lead to an accident.
If your kit manufacturer sells you a kit stating it has X amount of castor and you build it and find you are falling short of what they have stated and it does not allow you to legally pass the basic tests required to become road legal then you should be talking to you manufacturer and getting them to correct the problem FOC.
This all down to the very basic simple use of the jigs during construction whether that be on the chassis or the actual wishbones if they can not control the accuracies then quite frankly they should not be trying to produce the product and take your money.
Cheers Matt
cd.thomson
posted on 11/8/10 at 11:14 AM Reply With Quote
Cheers procomp,
I'd just like to say, from my standpoint, now that I've been informed of the issues by very knowledgable people like yourself and nitram (amongst others) I want to do everything I can to check the geometry is setup as well as it can be in a home garage.
I've cast a glance over my caster on both front wheels and its definitely 5 degrees plus, more like 7-8.
Craig
40inches
posted on 11/8/10 at 01:28 PM Reply With Quote
OK! I'll add some fuel to the fire.
As Procomp says, if the IVA tester finds anything fitted to the rack to aid self centering, you will have a fail.
The steering on my Indy was very tight, I disconnected everything one step at a time, starting with the steering column, and ended up with the rack, an MK shortened Sierra item, having no lubrication whatsoever I fitted a grease nipple on the centre section and gave it large with the grease gun, can now spin the steering wheel with my index finger With the car on stands.
cd.thomson
posted on 12/8/10 at 06:56 PM Reply With Quote
ill post this here rather than make a new thread (unless noone is reading!).
When sorting the geometry is there a specific order of things to do?
Should tracking come last/first etc?
Cheers guys, going to get stuck in tomorrow
Craig
procomp
posted on 12/8/10 at 07:00 PM Reply With Quote
Hi
Castor if adjusting.
camber
tracking
Assuming it's just the basics your setting up. IE not looking at bump steer etc.
Cheers Matt
cd.thomson
posted on 12/8/10 at 07:04 PM Reply With Quote
thanks for all the help in this thread matt, much appreciated
Craig
procomp
posted on 12/8/10 at 07:23 PM Reply With Quote
Hi
I missed the obvious first step. Set RIDE HEIGHT. Ideally as it would be with driver on board.
Cheers Matt
Mark Allanson
posted on 12/8/10 at 07:56 PM Reply With Quote
really basic checks - this is how the wishbones should look
Anotated castor
Anotated castor
A simple and cheap test of your castor using basic tools like this
castor 1
castor 1
and from above should look like this
castor 2
castor 2
You should have 22mm difference if using book suspension with Cortina knuckles
cd.thomson
posted on 13/8/10 at 05:27 PM Reply With Quote
after spending a few hours twizzling track rods am I right in concluding that I can't accurately set up my tracking (toe-in/out) at home? I need some sort of two wheel alignment gizmo?
My manual says I need to do tracking/camber/tracking because its not possible to accurately set camber if your toe-in/out is wrong?
[Edited on 13/8/10 by cd.thomson]
Craig
interestedparty
posted on 13/8/10 at 05:49 PM Reply With Quote
You can do tracking pretty accurately at home, and all four wheels too.
What you need is a flat, reasonably level surface, four axle stands or similar, some good quality string and a decent 600mm steel rule and lots of patience and carefulness.
Adjust the height of the stands so that where you tie the string to them is the same height as the hubs
basically you need to get a taut string line either side of the car, then move them about until they are parallel, AND so the car is centrelined between them (do that by maing sure that the distance from each hub to the line is the same, but remember that the back axle might be different width to the front.
When it's all set up, you can measure from the front of each rim at string height to the string, and then the rear of each rim, and that will tell you whether your wheels are lined up properly or not.
The more careful you are, the more accurate
And remember to re-check the string placement each and every time you trip over the strings
[Edited on 13/8/10 by interestedparty]
cd.thomson
posted on 15/8/10 at 04:29 PM Reply With Quote
found at least one part of the problem.
My lower ball joints are immovable .
Can just about get them to shift with a few whacks of a hammer but thats about it..
Craig
posted on 15/8/10 at 07:24 PM Reply With Quote
That's not going to help with the self-centring...
<<  1    2    3  >>
