<<  1    2  >>
Author: Subject: Carbon wishbones
hootsno1
posted on 19/1/11 at 08:50 PM Reply With Quote
can they be made out off billet ally???
ettore bugatti
posted on 19/1/11 at 09:12 PM Reply With Quote
IRCC fatique was attention point when engineering and constructing in billet ally. You could use airspec 6061 alloy for the uprights.
Formula Students have extensive analysis on their suspension and their reports are widely avaible on the web. Those crazy students aren't afraid to engineer in exotic materials
You could use filament carbon tubes, you then only have to figure a clever joining system
PS: Why is this in the bodywork section?
[Edited on 19/1/11 by ettore bugatti]
ettore bugatti
posted on 23/1/11 at 04:34 PM Reply With Quote
Informational link:
http://fsae.com/eve/forums/a/tpc/f/125607348/m/15110476641/p/1
Benonymous
posted on 25/1/11 at 12:42 AM Reply With Quote
Reminds me of an aluminium chassis thread
This thread reminds me of the many "why not build the chassis out of aluminium" threads.
If you want to save weight on a clubman style car there are many, many ways to do it without resorting to experimental parts in critical areas of the vehicle. The running gear is one area that I would never attempt to use exotic untested materials in.
Sure, F1 teams use CF for everything but an F1 car is unlikely to have a wheel drop into a pothole on a B road or clip a concrete kerb. I know F1 cars run over ripple strips on tracks and so forth but they are not putting massive instantaneous loads on the suspension when they do. I read an article once that pointed out "Carbon fibre has a very high strength to weight ratio but when it fails, it snaps like a carrot!" That's your wishbone he's talking about.
Metals tend to fail more progressively and so you'll avoid that look of a crashing F1 car with the wheels flying off in four different directions.
You'll never regret over engineering the running gear on your car but you'd definitely regret under engineering it.
coyoteboy
posted on 26/1/11 at 01:09 AM Reply With Quote
"PS there is a reason why only cross-country, and road bikes, have gone the CF route for main tubes. Downhill bikes would shatter like glass and stab the rider senseless in the event of the inevitable failure. Things break regularly on DH bikes due to the forces. I don't miss the falls one single bit, and I certainly don't miss the A and E wards I saw with regularity."
I've a 6" travel single-piv frame with a carbon swingarm, still going strong after nearly a decade of use
But I wouldn't use carbon on the wishbones for the two reasons I see noted above. 1 - when they fail they fail spectacularly - there'd be no pullin to the side of the road with a screech - it'd be snap, scrap, stop at best. 2 - the weight saving is minimal for the effort and concern I'd have over the final result. And I'm one of those crazy student types making stuff in exotic materials. We've billet uprights, carbon driveshafts, custom-housed minimalist diff, but our arms are still good old steel tubing
hughpinder
posted on 26/1/11 at 10:10 AM Reply With Quote
If its for a track only car then I'd say go for it!.
If its for a road car, I'd say save the sprung weight elsewhere - 13" wheels, thinnest/lightest brake disks etc
Regards
Hugh
Neville Jones
posted on 27/1/11 at 11:19 AM Reply With Quote
I like how folks have now cottoned on that those big wheels and rubber band tyres are heavy.
Not so long ago the slightest suggestion of binning those big bling wheels would have been met with shouts of derision, as happened when a close acquaintance of mine made the very same suggestion.
Nev.
Triton
posted on 27/1/11 at 03:30 PM Reply With Quote
I would say using carbo fibre for wishbones to save a knats knacker in weight wouldn't be worth the expense, if they were stroner enough for road use in the first place!!!
Fit a bike engine, 13" wheels and don't eat so many pies...........
www.tritonraceseats.com
www.hairyhedgehog.com
posted on 27/1/11 at 04:51 PM Reply With Quote
Think about this military combat helmets are made of Kevlar (they likely also contain glass fibres in the lamina) not carbon fibre.
interestedparty
posted on 27/1/11 at 05:47 PM Reply With Quote
That is how RCR (race car replicas), a big kit car firm in Detroit, do them, IIRC
Badger_McLetcher
posted on 27/1/11 at 08:36 PM Reply With Quote
Just to add another voice to this- No. Just no.
If disfunction is a function, then I must be some kind of genius.
MikeR
posted on 27/1/11 at 08:55 PM Reply With Quote
Can i go back and resuggest wrapping steel wishbones with fake carbon. It will add a couple of grams and will look the business (if thats your sort of thing) until it gets chipped.
B120WNY
posted on 27/1/11 at 09:04 PM Reply With Quote
What about making the wishbones out of T45 alloy?
They'll be substantially lighter than the steel ones, then you always have the option of wrapping in carbon fibre film to give them the look, they'll be light and look nice, but won't be as expensive or risky as the pukka carbon ones.
[Edited on 27/1/11 by B120WNY]
greggors84
posted on 27/1/11 at 09:45 PM Reply With Quote
At the start of last season HRT were running steel wishbones with carbon shrouds. If its good enough for F1....
Chris
The Magnificent 7!
shaft
posted on 27/1/11 at 10:15 PM Reply With Quote
We make carbon wishbones at work for 2 top F1 teams.
£25k for a set of 4 anybody? please bear in mind that doesn't include
the titanium end fittings for mounting or the bespoke match fitted rose joints
for adjusting them, but does include X-rays of each component and full traceability
of all materials used.
They are, however, 10x stronger than any alloy steel ones , but as mentioned
earlier by others, only in the direction they are designed to work.
You go over a kerb at a race track or a pot hole on the road, they won't even blink...
Nudge one forward or backward though and they'll snap like a carrot.
Joking aside, there's hardly any woven fabric in them. It's 90% UD (uni-directional)
material and hoop plies which are basically horse sshoe shaped hoops of UD
which go around each end and then fan out up each leg internallyy to load spread any pull
up the entire leg.
They are moulded in halves, 3D profile CNC machined, then bonded together in a bespoke
fixture in an Autoclave.
Woven is mainly used as edge trim to prevent spelching whilst machining them.
HTH
Nick.
EDIT: Forgot to say... the "Flexure" area of each leg is only 4.8mm thick!!!
[Edited on 27/1/11 by shaft]
my opinion might be wrong you know...
My Zero Build Pics
<<  1    2  >>
