mcerd1
posted on 11/5/11 at 06:36 PM |
quote: Originally posted by Thinking about it
Easiest way to tell if it will run the right way for rwd is to open the bonnet... if the gearbox is down on the right (most fwd cars) it goes the
right way, if the gearbox is on the left (drivers side) it runs anticlockwise aka Rover 416.
All Ford engines run the right way and bolt up to a type 9. Apart from the Duratec which came from some where else....
How that then Caterham use the 1.6 K Series. Im lost
cause alot of the 416's had honda engines not a K
the 1400cc ones were k's...
the 200/400 rovers are concerto's in disguese, some had BL engines, some had honda ones and the oil burners had Pug engines......
[Edited on 11/5/2011 by mcerd1]
littlefeller
posted on 11/5/11 at 06:46 PM |
my donor is an auto, was gona covert it, but it wouldent realy matter as the honda auto box is real good, i quite like it (didnt think i would when i
brought the car buying the honda was a must as i needed a car - quick).
[Edited on 11/5/11 by littlefeller]
mcerd1
posted on 11/5/11 at 09:33 PM |
you could stick the engine and its own box in the front rotated 90 deg.
then connect one driveshaft to a diff at the back and one to a diff at the front = 4x4 :lol:
Madinventions
posted on 11/5/11 at 09:49 PM |
FYI: There's a Mojo for sale with a VTEC already in it...
Link to thread...
The Mojo was designed by Jeremy Philips of Sylva Autokits, and is now owned by Typhoon Sportscars, so you could always contact them and get a
pre-built chassis if that's what you were thinking?
Ed.
View my band website:
http://www.shadowlight.org.uk
Madinventions
posted on 11/5/11 at 09:50 PM |
Typhoon Sportscars thread
Ed.
adithorp
posted on 11/5/11 at 11:37 PM |
"covert" an auto!
http://jpsc.org.uk/forum/
b14wrc
posted on 12/5/11 at 11:53 AM |
Go mid engined mate!
20vt powered rear engined locost
